Old 10/3/12, 6:49 PM
Jim Horton's Avatar
Jim Horton Jim Horton is offline
Default Air Return question
2001 modular home with a 1992 Coleman furnace. (down-flow)
Problems:
1)No return air grill(s) found.....
2)No furnace filters found....
Take a look at the photo's and give me your advise.
air-return-question-100_6584.jpg   air-return-question-100_6585.jpg   air-return-question-100_6637.jpg
Need a home inspection in Hawaii? Check out InterNACHI's listing of Hawaii certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/3/12, 7:06 PM
Michael Larson's Avatar
Default Re: Air Return question
The unit is probably centrally located. The return air is the grill you are looking at in your pic. I assume the door is provided with louvers.
Pretty common in modulars.
The filter is either in the door you took off, is missing or is supposed to be behind the cover in your pic.
What are you showing in pic 2?
If that is B vent it needs 1" clearance to combustibles.
Government is the great fiction, through which everybody endeavors to live at the expense of everybody else. -- Frederic Bastiat
Michael Larson
Hudson, WI
Old 10/3/12, 7:31 PM
Jim Horton's Avatar
Originally Posted by mlarson View Post
The unit is probably centrally located. The return air is the grill you are looking at in your pic. I assume the door is provided with louvers. Yes
What are you showing in pic 2? The top of the furnace.
If that is B vent it needs 1" clearance to combustibles. Yes it is a B vent.
It looks to me the large flex duct goes to the roof at the much smaller 2" pvc vent, drawing outside air.
Old 10/3/12, 8:40 PM
Jim Horton's Avatar
Where r all the HVAC guru's????
Old 10/3/12, 10:30 PM
Wayne B. Wilson's Avatar
were was the condenser ?
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 10/3/12, 10:48 PM
Jim Horton's Avatar
Not sure I understand what you are getting at?
Old 10/4/12, 1:09 AM
Mike Hazelwood's Avatar
Mike Hazelwood Mike Hazelwood is offline
The top cover grill should have the air filter. The top of the unit contains the blower (pulling air from the living area). More than likely that unit is located in the laundry room, correct? No closet door covering the unit, correct? If so, then door should be louvered/vented. The door or wall between the laundry room and living area should also be vented as to pull air from the living area.
Mike Hazelwood
Bakersfield, California
calpro@calproinspections.com
www.calproinspections.com
Old 10/4/12, 6:29 AM
Jim Horton's Avatar
Yes, correct on all accounts.
Old 10/4/12, 6:43 AM
Jim Horton's Avatar
I've got the answers for the initial two questions, with your guys input, thank you.
On the top of the furnace, Is this a correct installation where the (larger)flex duct going to the (smaller) pvc pipe through the roof?
And as Michael pointed out about the 1" clearance. I can see where I need to call this out,
If that flex duct is drawing outside air through that small hole in the roof, with no rain cap, then why not just do away with the flex duct?
Old 10/4/12, 10:30 AM
Charley L. Bottger's Avatar
I was out of town and on a roof last evening I am struggling with the thought that the 2 inch is outside air looks like a standard plumbing vent.
I need to know what the flex duct connects to at the furnace or does it. Down flow furnace with supply registers in the floor and the return on the front of the furnace that flex duct makes no sense
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 10/4/12, 10:38 AM
Jim Horton's Avatar
I agree with all you say as that is what my thoughts were. The flex duct connects to a flange at the top of the furnace, I assume for the return air.
It does not look right but I (like you) cannot understand why it was done this way. Puzzling???
Old 10/4/12, 10:46 AM
Surley the flex is part of the return could you see where it terminated above the furnace or did it just disappear into an attic area
NACHI Member
State License # 130
Old 10/4/12, 10:55 AM
Jim Horton's Avatar
Cathedral ceiling with no attic.
Old 10/4/12, 11:13 AM
Jim Horton's Avatar
I just got a call from a local HVAC guy that said he couldn't explain why it is the way it is but he could fix it by having the flex duct mounted above the door header with a new register instead of up through the roof.
That sounds like a plan.
What do you think Charley?
Old 10/4/12, 11:32 AM
I understand that but where does the flex duct go when it leaves the furnace connection/flange
NACHI Member
State License # 130
Supply vs. Return Register Placement cevans Inspecting HVAC Systems 12 2/27/10 11:29 AM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
air return question. AdamAdam Inspecting HVAC Systems 5 12/3/06 2:48 PM
