Old 11/21/06, 10:00 AM
mmorgan mmorgan is offline
Default Is this allowed??
Small pipe is water heater flue. Larger one is furnace flue. It there an issue with them being tied togather like this??
Thanks
Old 11/21/06, 10:19 AM
David A. Andersen's Avatar
Default Re: Is this allowed??
The fitting where the to pipes connect does not appear to be adequate, however I cannot see through the pipe.
The main flue pipe (to the roof) must be the size of the largest pipe plus 50% of the second or additional pipes. I don't see this happening in your photograph.
Old 11/22/06, 9:50 PM
Steve Alexander Steve Alexander is offline
The pipe from the water heater appears to be single wall. If so, there is an issue with clearance to combustibles.
Old 11/23/06, 10:14 AM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
It appears that the two double wall pipes are not properly seated and locked together. The bottom double wall pipe has a hole cut into the side of it for the other smaller double wall pipe. A no no. And single wall pipe completes the connection. I would take it that this is an unheated attic? Then Double wall pipe, tee and appliance connector must be used. Period.
Old 12/22/06, 2:51 AM
Jeremy Tucker Jeremy Tucker is offline
Please Note: Jeremy Tucker is a non-member guest and is in no way affiliated with InterNACHI or its members.
I second this motion!
Aluminum Ground - Allowed?? mwright1 Electrical Inspections 26 6/12/10 12:22 PM
Are roof rafter notches allowed rchorey Structural Inspections 25 2/23/09 8:05 PM
Check Inside Electric Panel ? not allowed rcooke Canadian Inspectors 41 2/15/07 4:14 PM
How many wires did you say were allowed? jtedesco1 Electrical Inspections 16 6/8/06 12:30 AM
When were panels not allowed in clothes closets? jtedesco1 Electrical Inspections 43 3/2/06 1:37 AM
