Is it o.k. to use aluminum for a natural gas vent pipe? It did change to B-vent before the ceiling penetration. I don't recall ever seeing aluminum single wall before. Any help, input, criticism, etc. is always appreciated.
| Find an InterNACHI certified Florida Home Inspector (and anywhere else in North America) |
I guess you need to get the specs on that pipe and that of the equipment...
Are you getting outside of your scope with this? If your getting paid for it, I guess that's fine. Go get the answer for the client. I do this all the time. Looks like you have an 80% furnace, flue temps are down. Alu displaces heat better than steel. I just can't comment from here. Insufficient info. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
gkay is a non-member guest and is in no way affiliated with InterNACHI or its members.
The interior pipe of b-vent is aluminum. There should be no problem.
Not much of anything to say about components inside a manufactured/listed unit, as long as it is not modified.
The B vent doesn't have the 1" clearance into the ceiling....
Tim |
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 36 | 10/27/10 11:21 AM |
| Pellet stove help | chellickson | General Inspection Discussion | 23 | 8/19/10 2:23 AM |
| Is this allowed? | relliott | Plumbing Inspections | 4 | 7/15/09 7:40 PM |
| Identify ABS defective pipe | mcyr | Plumbing Inspections | 6 | 1/29/09 7:39 PM |
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 1:35 PM |
