Old 12/23/09, 11:24 PM
Paul Pendley Paul Pendley is offline
Default What am I missing
Something doesnt look right....Can anyone help?
This is the best/only photo I have....copper pipe at condensor/furnace in garage....the refrigerant lines are on the side. Im guessing something pretty simple but my brain checked out today.
Paul Pendley
Premier Property Inspections
866-458-8516
Find an InterNACHI certified California Home Inspector (and anywhere else in North America)
Old 12/24/09, 12:29 PM
Jeffrey R. Pope's Avatar
Default Re: What am I missing
Looks like the secondary drain. Needs to be piped or capped.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/24/09, 1:17 PM
Wayne B. Wilson's Avatar
Yep thats what it looks like
Old 12/24/09, 2:54 PM
David A. Andersen's Avatar
Cap it!
BPI# 5015804
Old 12/26/09, 12:15 PM
staylor5's Avatar
staylor5 staylor5 is offline
the secondary drain is a backup to see if the piped drain is clogged. If you see water coming out of the secondary drain the system is clogged and repair is needed. This should only be capped if it can damage a finished surface.
Old 12/26/09, 1:17 PM
Can't see it here, however these coils are very often located above a gas-fired furnace and water flowing into the furnace will destroy it!
If you don't use it, put a cap on it.
We don't need to be blowing air into an unconditioned space either.
BPI# 5015804
What is missing? kmalone Electrical Inspections 8 2/3/09 8:42 AM
Whats missing Here?? psmothers Inspecting HVAC Systems 7 3/18/08 4:25 PM
Water Heater label missing rnewman1 Plumbing Inspections 3 9/19/06 7:15 PM
