Hey guys
Currently I turn on emergency heat first to see if the heat strips are working. I have heard some guys do amp draws. I tried finding information on the this procedure but I can't find it any where. What does this procedure consist of? Juan Jimenez
A House on a Rock Home Inspections LLC God. Family. Home. 571-208-3286 http://ahouseonarock.com Richmond, VA Home Inspector Richmond, VA Radon Tests Recommend US! http://www.facebook.com/RichmondHomeInspector |
| Need a home inspection in Idaho? Check out InterNACHI's listing of Idaho certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Can open panel, there are several places to clamp your amp meter to. Mainly Hot wire, BUT and I say BUT again, if you have not done it before, befriend a local electrician in your area, and he can show you !
Juan I will say one thing for you.
You are not afraid to try new services . |
I look at all possibilities in this business. It's my job to continue to learn about every little thing. I know you think I'm cocky and foolish but I really do have a grasp of what I'm doing here. I am also fully aware that I have a lot to learn. Juan Jimenez
Thanks James. I will do that.
Juan Jimenez
I tried Charley!
Juan Jimenez
Ok I forgot they remove the pics after a while here is another set.
This furnace had 3 elements deonted by the three round limit switches one has a black wire the other two have yellow wires color makes no difference inside the furnace, In order to check the individual elements you must clamp the amp meter around each individual element's wire. You are not looking for a specific amp draw but rather a lack of amp draw indicates a open circuit. These little nicrome wire heating elements are 240 volts thus you can read amp draw from either side of the element it matters not Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Try this one
Gotcha! So it's kind of like checking breaker temps? You aren't looking for a specific temperature but rather an anomaly?
Juan Jimenez
Don't sticking anything in that panel Juan unless you get some decent hands on training first
Please Government is the great fiction, through which everybody endeavors to live at the expense of everybody else. -- Frederic Bastiat |
Just be careful Juan . Charley is right on. and in my opinion no worst than opening a panel .
Thanks guys. I'll be sure to be careful.
Juan Jimenez
Pretty simple you are looking for no amps period. No amp draw equals open circuit. These elements are activated by the sequencer as needed according to indoor temp. The short of it is you must turn the stat up to ensure the second sequencer is activated or calling for heat before determining that you have an open circuit (no amps)
Juan Jimenez
| Draw Inspections down??? Not too much work from Digital Draw anymore... | jwatts1 | General Inspection Discussion | 5 | 10/27/08 7:15 PM |
| Draw inspection companies changing % | jwisecup | Miscellaneous Discussion for Inspectors | 31 | 5/12/08 5:08 PM |
| Questions on Draw Inspections? | bskinner | Miscellaneous Discussion for Inspectors | 46 | 1/24/08 10:44 AM |
| Questions on Draw Inspections | bskinner | General Inspection Discussion | 9 | 1/18/08 10:27 AM |
