This was from today's inspect gas fired furnace 80 % efficient located in the attic with primary, secondary condensate drains installed with safety pan.
Who can explain why the drains are wrong and no you do not have to be a CMI to answer. Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging Last edited by cbottger; 5/13/08 at 10:18 PM.. |
On second glance, what appears the be the coil's secondary drain in going into the drain pan. Where does it go from there???
Ya just gota wonder sometimes what people are thinking, well when there not.
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
</IMG> Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Hard to tell from just pictures.
1) Drain line drains into the pan,.. 2) The exterior drain pipe is higher then the pan. Potential overflow - water takes the path of least resistance. Peter Doane Realty Check Inspection Service NACHI ID# 05120681
Come on guys this one is just glaring at you don't let them CMI's out do you
The overflow pan piping goes higher than the top of the pan. Neato.
No vent on the drain. The top vent appears to be capped.
In my area, they want these pipes insulated in an open attic. Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
You guys are wearing the wrong hat today I placed the answer to this question in my first post??????
Is it insulated inside the metal?????????
I know it is right in front of me Charley and it is killing me................
| USA case law on Home Inspection | rwand1 | Canadian Inspectors | 10 | 5/23/09 11:30 PM |
| ............... And there is nothing wrong with our legal system | gbeaumont | Miscellaneous Discussion for Inspectors | 17 | 7/7/07 12:10 AM |
| Grandpa, what is wrong with the patio? | mcyr | Exterior Inspections | 1 | 5/12/07 10:29 PM |
| Case law on Home Inspections | rwand1 | Canadian Inspectors | 17 | 4/5/06 10:08 PM |
