Whats wrong with running propane in a natural gas forced air furnace?
and what can be done to make it safe? |
The orifice needs to be changed
That still doesn't answer the question, I know they are different sizes, but why would they even need to be different sizes?
Propane his heavier than air and denser than Natural Gas.
Propane and natural gases are delivered at different pressures for one thing.
Natural gas is lower pressure than L.P. Plus I'm sure their properties and make up are different. Therefore, different size orifices. John Springstead Home Inspections of USA 1752 N.E. Torch Lake Dr. Central Lake, MI 49622 1-231-544-8016 office 1-231-544-6001 fax www.homeinspectionsusa.us |
conversion kits are available.
the heating value of propane is approximately 3 times higher than natural gas, therefore the orfice size is smaller since less gas is required.
The difference has to do with the burn temps of each gas (I don't have the #'s in front of me).
You can burn out the appliance if you are burning the wrong fuel. . . IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Fuel-Natural Gas ( CH4 )
- Comprised mainly of methane (81%) - Lighter than air (specific gravity .65) - BTU content/cu.ft. =700 to 1200 - Ignition temperature of 1100° to 1200°F - Typical manifold pressure = 3.5” WC Propane ( C3H8 ) - Comprised mainly of propane (95%) - Heavier than air (specific gravity 1.53) - BTU content/cu.ft. =2500 to 2700 - Ignition temperature of 920° to 1020°F - Typical Manifold pressure = 11” WC Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
| Sump Pit/Pump Question | Joey D'Adamo | Plumbing Inspections | 4 | 11/26/08 2:04 PM |
| Interesting Question? | jmckenna1 | Miscellaneous Discussion for Inspectors | 9 | 11/25/07 2:13 PM |
| WA State Legislative update | hmiller | Legislation, Licensing & Legal Issues for Inspectors | 153 | 5/5/07 12:55 AM |
| Rule of Thumb A/C sizing question from Practice Exam | gliebig | Inspecting HVAC Systems | 9 | 5/25/06 2:38 AM |
