I've been seeing a lot of HEIL furnaces and AC units lately (new ones). Does anyone have info on their Model and Serial number codes? That's a brand that my notes don't cover. I don't recall seeing any older ones, so I'm thinking that they might be a new brand name (but that's just a guess, based on my perception.)
HEIL - See International Comfort Products, LLC The model number and serial number are printed on the unit's rating plate normally located on the outside jacket of the unit. Model numbers appear in the following typical format: PGC036K060A; serial numbers appear in the following typical format: L004112345. To determine the date of manufacture of an Heil unit, use the first four numbers of the serial number. The first two numbers represent the year, and the third and fourth numbers represent the week of manufacture. In the sample number provided the unit was manufactured the 41st week of 2000. HEIL Recall - Originally issued 19 Oct 2005 InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
I just ran across this one today and that system doesn't make much sense to me.
MFr No. 94356 Serial No. H 55120465 Model No. CU229AQD1C Thanks! Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowledge will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.sheboyganhomeinspector.com www.4squarehi.com Like Us on Facebook Follow Us on Linked-In |
Something is strange with yours... Notice the serial number isn't stamped like the other numbers but is a sticker covering the area up. Wonder whats up with that?
I just pulled that out of the air, so you would want to make appropriate corrections and edits to your situation. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
Serial Number Format H61139301 Using the first and second digits of the serial number H61139301 you will find the yar of manufacture. The first digit (Always the letter "H" for the 1980's.) is the decade of manufacture and the second digit is the individual year within that decade. The sample number provided is from an actual unit that was manufactured in 1986. In your serial number Serial No. H 55120465 the unit was manufactured in 1985. www.buildingcenter.org Quickly determine the date of manufacture, age or production of most HVAC and Water Heating equipment |
Hummm,
Prestons list that model number as being from 1975 only. How you been John, long time no see Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Prestons puts the model number as manufactured between 1973 and 1978
Efficiency ratings varied throughout those years as well. With an altered serial number tag the possibility of something significant having been replaced in 1985 could be considered that changed the efficiency and which required a new or updated serial number but allowed the model # to remain the same. Without repair receipts or some sort of service record history it becomes difficult to determine. Regardless, 25-30 years estimated age would seem appropriate for this circumstance. Submit your AWARDS NOMINATIONS here Visit the InterNACHI Awards web portal here Blessed are the blissfully ignorant... for they shall be easily led...
Thanks!
| Allergy Testing in Coeur d’Alene, ID 83815 | rspriggs | Ancillary Inspection Services & Additional Topics | 3 | 10/12/09 2:39 AM |
| Importance of the AHJ check | mcyr | General Inspection Discussion | 6 | 2/21/07 8:18 PM |
