Old 11/20/09, 8:14 PM
Gerald C. Wilcox's Avatar
Gerald C. Wilcox Gerald C. Wilcox is offline
Default Asbestos type insulating board
Found this recently, it probably is asbestos and will have it lab tested. I am not familiar with asbestos in this form, what can you tell me about it? The return air was panned with this product and is not used, as the forced air furnace was replaced with a hydronic boiler many years ago.
ID:	33430   asbestos-type-insulating-board-asbestos-insulated-board-010-small-.jpg.jpg
ID:	33431   asbestos-type-insulating-board-asbestos-insulated-board-006-small-.jpg.jpg
Find an InterNACHI certified Idaho Home Inspector (and anywhere else in North America)
Old 11/20/09, 9:48 PM
Chris E. Donofrio's Avatar
Chris E. Donofrio Chris E. Donofrio is offline
Default Re: Asbestos type insulating board
yep see lots a that stuff around here, even 4x8 sheets behind wood stoves and such.
Old 11/21/09, 12:24 AM
Any specifics about the product? Where and when it was manufactured?
Old 11/21/09, 2:18 AM
Gary Oleski Gary Oleski is offline
Asbestos Millboard -
Asbestos Millboard was used in the construction of walls and ceilings, particularly around furnaces and wood-burning stoves where insulation and fire protection was required. Most varieties of asbestos millboard typically contained between 80 and 85 percent asbestos.
In 1977, the use of asbestos in most construction materials was banned by the Consumer Product Safety Commission. The ban was enacted due to the known dangers of this substance. Asbestos fibers, when inhaled into the lungs or otherwise ingested, can potentially cause diseases such as asbestosis and mesothelioma, both of which have very high mortality rates. These diseases are most commonly caused by long-term asbestos exposure over several years, but mesothelioma has been known to be caused by even very short term exposure.
The presence of materials such as asbestos millboard in your home is not necessarily a cause for alarm. These materials are safe as long as they are in good condition and are not disturbed. Asbestos is dangerous only if fibers are releasing into the air and are able to be inhaled into the lungs.
If your home was built during or before the 1980s, it is possible it may have been built using asbestos millboard or other asbestos-containing construction materials. While materials that are intact and in good condition pose little danger, it is important to know whether asbestos-containing materials exist in your home so that you monitor the condition of the materials. It is particularly important to find out if you are planning to remodel or renovate, as this is likely to cause disturbances that may release asbestos fibers into the air.
More info----- http://www.asbestos.com/products/
Gary Oleski Home Inspections
Home Inspections Connecticut
Connecticut . 06610
NACHI04012833
CT#HOI.341
C M I
Old 11/22/09, 9:53 AM
Thanks, I had never seen return air ducting panned with AIB Asbestos Insulating Board or Millboard. It evidently came in larger sheets and was scored and broke to size. What a poor choice I remember a fellow an old HVAC guy who used to say how they had 50lb bags of the stuff and dumped it in barrels and added water to mix to insulate furnaces, boilers, piping and ductwork.......Poor fellow.
Question about exposed styrofoam insulation. mlong Exterior Inspections 9 12/21/07 9:33 AM
Asbestos jlybolt Exterior Inspections 38 7/17/07 2:13 AM
Massachusetts Board of Registration of Home Inspectors jtedesco1 Legislation, Licensing & Legal Issues for Inspectors 0 2/14/06 4:38 AM
New Hampshire Real Estate Agents Are Upset! fcarrio General Inspection Discussion 8 2/11/06 2:35 PM
No Ashi / Nachi Conflict!! fcarrio Legislation, Licensing & Legal Issues for Inspectors 5 2/11/06 2:32 PM
