To all the HVAC vets.......Is it better to install an attic air handler by hanging from rafters or to install on ceiling joists (with vibration pads)? Should the air handler be insulated?
Thanks in advance. |
| Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Your post is not specific enough to provide much of a comment. air handlers are required to be installed according to the manufacturers written specifications. While means of draining condensation, required pan, distance from access, working platforms, lighting, and means of disconnect are dictated by the building codes in affect for your local jurisdiction. As far as additional insulation that would not be advised as it would serve to trap condensation between the air handler cabinet and the insulation causing corrosion. Mark S. Tyson M Tyson construction LLC Tyson Home Inspections Certified General Contractor #1516843 Florida Licensed Home Inspector #1824 Member N.A.C.H.I. IAC2 certified Member Florida Building Officials Association http://www.TysonHomeInspections.com |
I agree with what Mark said and in this area, they are mostly hung from unitruts spaning rafters and mounted on spring& rubber isolaters.
Cat walks are necessary on most models for servicing, lighting and service outlet should also be provided out of commen sense or as required by the manufacturer or AHJ. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Not a bad answer Mr. McHammer Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Well, I have built enough cat walks for them Charley, and I don't like to run for a light and an outlet to plug my tools.
Bill Crowley is a non-member guest and is in no way affiliated with InterNACHI or its members.
I am a Master unrestricted Sheetmetal Mechanic. I have been in the business for 35 years. If you can hang the unit from the upper trusses or from the roof rafters this is the most proffesional installation for many reasons. However sometimes there simply is not enough ceiling height to hang the unit and building a platform is necesary. The most proffesional device for installing either way is the www.Quick-Sling.com Hope this helps. |
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 6:31 AM |
| Roof decking condensation. | Homewood | Interior Inspections | 15 | 3/5/10 11:00 AM |
| Shooting to begin on comprehensive new roofing courses | kshepard | Inspection Education & Training | 4 | 11/7/09 2:59 PM |
| Mold question? | ccurrins | Interior Inspections | 35 | 1/23/09 11:55 AM |
