Hey guys I'm looking in my code book and noticed that their should be a solid floor from the access door to the furnace I have a 2 foot gap that you must cross with no support (Sheetrock Underneath it) See pic
Any interpretation will help REF: IRC 1305.1.3 Thanks Troy Farmer Presidential Inspections LLC Chapter President Southern Idaho PO Box 2144 Eagle, Idaho 83616 208-573-5300 http://www.presidentialinspection.com http://info@presidentialinspection.com "He who can, does. He who can’t, teaches" "Where would we be without Teachers" |
Sorry I thought the pic was up OOPS
Yes. It will keep the fat HVAC guy with his coffee and doughnut from stepping through the ceiling.
Are enforcing codes too?! You don't need an interpretation of the code. Just write up the common sense of it all! |
rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
I interpert it as needing a full pathway between the opening and the furnace.
Troy ,, I read it the same as you, the only exception would be if the unit could be serviced from the opening. From your pic it doesn't look like that would be possible.
I agree David, commen sense says have it fixed! Rick Slocum NACHI # 04072697 Elizabeth CO 80107 ABSOLUTE Home Inspection Service |
I knew it didn't look right when I saw it so I looked it up and then asked for Interpretation. Thanks again Troy Farmer Presidential Inspections LLC Chapter President Southern Idaho PO Box 2144 Eagle, Idaho 83616 208-573-5300 http://www.presidentialinspection.com http://info@presidentialinspection.com "He who can, does. He who can’t, teaches" "Where would we be without Teachers" |
When and if I see a safety issue, it's noted in the report. Whether it's code or not.
And the Realtors always ask me why my reports are so full. Hmmmmmmmm.... |
I love the builders that say it's ok cause it passed code inspection! Quote:
As to not quoting a code to anyone; I quote them to builders that just can't get it. Then I note that maybe it is not enforced "here" but the safety ramifications can not be ignored. Life will be so much easier for the inspector who keeps out of this battle. You have no enforcement powers. You may not interpret the code the same way as the AHJ. The builder often does not "perceive" things through your eyes. My client holds the enforcement powers , in his checkbook. Interpretation is just common sense "that's just wrong". I don't know what will impact the clients family dynamic, nor does the builder. |
He asked a specific question and I answered the question. I personally think that people rely too much on codes. I always try to figure out the intent of the code and use that as my reasoning for following the code. However it can be hard to back up assertions without something (besides your good looks I guess I have one more post under my name now!!! </IMG> |
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 6:31 AM |
| Horizontal Furnace in Attic | Anthony Joseph | Inspecting HVAC Systems | 5 | 10/12/07 9:08 AM |
| Propane gas to attic furnace | brepanshek | Inspecting HVAC Systems | 5 | 2/21/07 5:06 PM |
| Cat 1 Furnace in attic | wdecker | Inspecting HVAC Systems | 2 | 6/14/06 1:28 AM |
