Old 5/21/08, 12:25 PM
Evan J. Hughes Evan J. Hughes is offline
Default Bacharach Monoxer II vs tif8800A Combustible Gas Detector
Hell, I have a question for all of you. I use both a Bacharach Monoxer II and tif Combustible gas detector at my home inspections. I have always been unhappy with the bacharach, and honestly do not trust it. I have had it calibrated by Bacharach and it still does not work to my satisfaction. I started using the combustible gas detector also and it seems to work very well for determining if CO is in the air. I was told that this detector works by looking for a lack of oxygen in the air. It basicall will work for both applications......co gas, and combustible gas. I have also talked to several HVAC guys who do the same thing. What are your opinions on this? I understand that with the combustible detector I can not get exact CO readings, but is this really needed, when there should be 0 co levels. I am thinking of selling the Bacharach and using the money for a moisture meter, but just want to know other people's opinions on the issue. Thanks in advance.
Evan Hughes
Colorado Pro Inspect
Evan Hughes
10621 Cherry Street
Thornton, CO 80233
ehughes@coloradoproinspect.com
www.coloradoproinspect.com
Old 5/21/08, 12:39 PM
Michael Larson's Avatar
Default Re: Bacharach Monoxer II vs tif8800A Combustible Gas Detector
Tif 8800 Combustible Gas Detector
Applications:
Gas lines and pipes, aids in identifying Heat Exchanger leaks and hazardous living/working environments. Note: not an effective Carbon Monoxide detector –
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 5/21/08, 12:46 PM
Jon Randolph Jon Randolph is offline
Please Note: Jon Randolph is a non-member guest and is in no way affiliated with InterNACHI or its members.
I also use the Tiff 8800A, at least initially. I have been told that it does not detect CO, but does detect the aldehydes that are often associated with incomplete combustion. The aldehydes (I believe) is what is usually smelled in the home when there are exchanger issues (CO is odorless).
Remember that the TIFF is very sensitive and may also pick up styrofoam and/or other debris left in heating ducts as well as some thread sealants and (maybe) air freshners. I will use the TIFF initially, but I do not totaly rely on it for CO. I use a TPI775 to test specifically for CO.
Old 5/22/08, 9:43 PM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
What problems are you having with the Monoxor II? Maybe I can answer your questions about its operation.
The TIF 8800A is a combustible gas meter and should not be relied upon for co testing.
Using a TIF8800A combustible gas detector soehmen Inspecting HVAC Systems 9 5/17/08 3:41 PM
