Hi I did a home inspection today and found four thermostats each in a different room. There is not a single vent in the home which is a condo, and there are no base board heaters either. What am I missing????
Thanks Mark </IMG> |
jwisecup is a non-member guest and is in no way affiliated with InterNACHI or its members.
Radient floor heat with a commen boiler, maybe. they also make electric type radient floor heat-thou I haven't seen any installed-just available for purchase.
Jamie |
Thats what I was thinking but the condos only have one garage and it belonged to my client. All the condos shared a hot water heater which was in the garage but no boiler that I could find. I did turn on all of the thermostats let them run for over an hour and the floors all felt the same as before I turned them on. I am going to get in touch with the property manager and see what the deal is. I cant ask the seller as it is a probate sale by the state the original owner died so no dice there.
Thanks for your help Mark |
hmmm, that is odd. Let us know what you find.
Jamie |
wforsyth is a non-member guest and is in no way affiliated with InterNACHI or its members.
Controls for a secret room where he houses his "prisoners".
whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hey Jamie,
You're in California, chances are it's electric radiant ceiling heat. Should have found individual breakers at the panel for same. It's normally a low amp feed and can take 30 minutes or longer before you can detect a ceiling temperature change. |
Thanks Will, That sounds like California not here in Colorado, I used to live in South Laguna many years ago I'm in Colorado now-Mark was the one that found this -I was just guessing-but wouldn't have guessed ceiling heat.
jamie |
ONLY in California would they devise "Ceiling Heat". What ever happened to "heat rises"???
In the panel there were two 20 amp breakers labeled heater. another clue to the mystery! I am going to see if it has ceiling radiant heating. Although there is no attic to access I will get the info from the home owners association. I am going with the secret room for prisoners for now though.
Thanks Again Mark |
http://dulley.com/docs/f778.htm http://oikos.com/esb/37/radiant.html http://www.radiantpanelassociation.org/i4a/pages/index.cfm?pageid=97 http://www.clarkpublicutilities.com/...s2005/05_02_20 The only negitive information I have found is from people who have no idea what it is . I have received many emails and not one said any thing bad . Will Post my thoughts soon . Roy Cooke ,... RHI.... Royshomeinspection.com.. CAHPI-ON... |
I would have utilized my infrared thermometer and scanned the entire room (with the switch ON).
Roy Cooke </IMG> |
tdutt is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have been a drywall finisher and contractor for 20 years, and have only seen this kind of an installation a couple of times, and they are a real pain to work with. If you had to put 5 screws or nails in a ceiling, chances are 1 of them would hit one of those wires as they are spaced so closely together. Last edited by tdutt; 8/19/06 at 11:34 AM.. |
| CPSC NOTICE- Supplemental Heating Warnings | pabernathy | Electrical Inspections | 0 | 1/29/07 4:35 PM |
| Another reason to recommend CO testers | rnewman1 | Interior Inspections | 2 | 10/12/06 7:47 AM |
| Ceiling radiant heating | rcooke | Electrical Inspections | 7 | 8/19/06 11:07 PM |
| Ceilings falling with wires in it. | jsmith3 | Interior Inspections | 9 | 3/16/06 7:24 PM |
| outlet above baseboard heater | aspisak | Canadian Inspectors | 3 | 3/16/06 6:52 AM |
