Old 2/19/09, 7:38 PM
Steve A. Rinner Steve A. Rinner is offline
Default BAsement Cold Air return
Is there an issue with having a cold air return in the basement? Does not seem right.
Your thoughts will be appreciated.
Thanks
Steve Rinner
GLH Home Inspections
Norwalk, Ohio
Old 2/19/09, 7:46 PM
Default Re: BAsement Cold Air return
It shouldn't be within 10 feet of the furnace...
Larry Kage, CMI
231 929 3525
Old 2/19/09, 9:13 PM
David C. Macy's Avatar
Negative pressure can be created and combustion products can be blown throughout the home.
Old 2/26/09, 5:46 PM
Steve,
If I am seeing/understanding YOUR picture in total, this particular installation would not be a problem (at least in my area of the country) because of the shear volume of the space, and the placement of the WH in the space in relation to the return air opening in the R/A plenum.
The problem(s) will occur when the owner decides to enclose the mechanical equipment. He/She may or may not know how the changes they make will effect the operation and/or safety after the addition. I've seen obvious professional contractors work, when the made mistakes in their design of the enclosure.
Old 2/26/09, 8:51 PM
Keith R. Braun's Avatar
Keith R. Braun Keith R. Braun is offline
Ditto to all of the above, plus I don't advise introducing basement air into the circulation. (No return air in kitchens, bathrooms or basements) Maybe there is not a sufficient amount of R.A. grilles, causing the furnace to run hot - this was the installer's solution.
something else to chew on john bubber Structural Inspections 706 4/25/12 7:13 AM
Site grading and drainage wdevries Canadian Inspectors 5 10/6/09 10:23 PM
Options in selecting materials for basement construction wdevries Canadian Inspectors 2 8/4/08 1:30 PM
cold air return in basement? bmargiotti Inspecting HVAC Systems 10 1/24/06 5:51 PM
