We all know that venting of the bath fans at the soffit vents in the attic is bad. Is it code? Anyone have a code # so I can give the builder who is telling me its ok? Thanks in advance.
Peter Doane Realty Check Inspection Service NACHI ID# 05120681
bbenjamin is a non-member guest and is in no way affiliated with InterNACHI or its members.
International Mechanical Code: 401.5.2 Exhaust openings.
Outside exhaust openings shall be located so as not to create a nuisance. Exhaust air shall not be directed onto walkways. |
This might help although not Code related.
Duct the fan to the outside and seal the line Retrofitting a bathroom with an exhaust fan can be a pain in the neck. You’ll have to cut a hole in the ceiling for the fan, install a vent through the roof or a gable-end sidewall and connect the two with a duct. Taking shortcuts, like running the duct to a soffit vent or the attic and calling it good enough, may be tempting but ultimately aren’t worth it. Some points to keep in mind:
Follow the Manufactures listed Instructions on the Installation. Code only provides you with ventilation minimum requirements where a window that opens is good enough. Sometimes Codes are not the best options because it is the bear minimum requirements in the Building Industry. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I don't like the bath vent terminating in the soffit, but some people can get away with it. The actual code text is a little fuzzy:
IRC 2003 M1506 MECHANICAL VENTILATION M1506.1 General. Where toilet rooms and bathrooms are mechanically ventilated, the ventilation equipment shall be installed in accordance with this section. M1506.2 Recirculation of air. Exhaust air from bathrooms and toilet rooms shall not be recirculated within a residence or to another dwelling unit. I personally consider a bath vent that terminates in the soffit to still be "within a residence", but I'd be hard pressed to tell you how it might recirculate. Clothes dryers are much more cut and dried, but bath fans; not so much. Best I got... |
arussell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Pete
It's been my experience though not in the codes most local officials don't allow it. I'd make a quick call to the local building dept. and ask. Couldn't hurt and it'd be good fyi. |
| Complex challenge with bath exhaust fan - need help with solution! | Bill Featherstone | Electrical Inspections | 11 | 11/5/07 1:16 PM |
| Bath exhaust fan opinion | rgiglio | Plumbing Inspections | 6 | 3/16/07 3:06 PM |
| Water Heater Venting | dedwards | Plumbing Inspections | 1 | 8/19/06 12:46 PM |
| Bad Dryer and Bath Fan Venting | Jkrt00 | Inspecting HVAC Systems | 3 | 3/13/06 11:07 PM |
| For anyone who needs info on venting! | pbolliger | Inspecting HVAC Systems | 8 | 2/18/06 8:58 PM |
