Old 10/25/09, 5:35 PM
Steven C. Waskewicz's Avatar
Steven C. Waskewicz Steven C. Waskewicz is offline
Default Bathroom vent piping to "Near Exterior"?
Because of the dry climate where we are, I usually don't make an issue out of this type of plumbing vent run for bathroom fans.
I thought I'd post this recent inspection shot that I did, to see what others think about this?
I believe the perfect solution should be a vent, directly to the exterior.
(And in the imperfect world we live in, it sure looks like this would solve any possible moisture problems,
at least here in low-humidity-colorado.)
Opinions welcome.
Steven Waskewicz
Colorado Springs, Colorado
719-510-7703
Rest Assured Inspection Services, LLC.
719-510-7703 mobile all the time
Find an InterNACHI certified Maine Home Inspector (and anywhere else in North America)
Old 10/25/09, 6:46 PM
Billy Boerner's Avatar
Billy Boerner Billy Boerner is offline
Send a message via Yahoo to bboerner
Default Re: Bathroom vent piping to "Near Exterior"?
Opinions welcome.
I agree vent directly outside however since it's legal simply venting them to the gable vent without having to cut holes in the roof is the preferred method to save money for builders.
Bill Boerner
STL Home Inspection Services LLC
Serving St. Louis/Surrounding
(314) 805-2137
office@stlhomeinspector.com
http://www.stlhomeinspector.com
Residential, Commercial, Radon, Termite, Lateral Sewer Scopes
Old 10/25/09, 6:49 PM
Bob Elliott's Avatar
I would be more concerned if it was a dryer vent ,but in a cold climate such as yours , is there not a possibility of freezing up the opening and cutting off attic ventilation.
Old 10/25/09, 7:47 PM
mnahrgang's Avatar
For new construction around here, the AHJ's (St. Charles) want the vents 18 inches above the insulation. To a gable, to a soffit, or to the exterior is ok too. We've got pretty humid summers, and I've not seen much issues with this. The only issues I've found is rusted nails from winter condensation/thawing/dripping and that was an older home. Relatively speaking, you almost never see bathrooms vented to the exterior here.
Mark Nahrgang
www.HeyMark.info
Old 10/25/09, 7:52 PM
Dave Bush's Avatar
Dave Bush Dave Bush is offline
Mark, same thing here, as long as it is 18" above the insulation, it is considered sufficient here.
Dave Bush, CMI
Quality Home Inspections
Serving Joplin, Neosho and Southwest Missouri Area
417-850-9820
"Always do what's right, not what's popular"
Old 10/25/09, 8:05 PM
Opinions welcome.
Steven, is that two bathroom vents and one dryer vent in the smooth duct.?
Makes to much sense to just vent up through the roof with a $5 vent cap?
Hate to see what happens with a prevailing wind, and no ridge vent.
Why is the felt paper directly on the truss framing.?
I know, I know, I ask to many questions right.?
Old 10/25/09, 8:07 PM
So you guys in Missouri have no problem with intentionally soaking the underside of roof sheathing that creates mold. ?
We are talking warm ,humid air.
OK.
In that case i guess blocking the Gable vent is fine and dandy.
Old 10/25/09, 8:16 PM
mnahrgang's Avatar
OK.
That's just it... The humid bathrooms venting to the attic apparently cause no harm. My own home for example has the vent directly into the insulation. There is no ducting at all. Zero, and I say again, zero moisture problem in the attic. Apparently the natural ventilation of the attics around here is sufficient. I've only found one older home that had any problems at all, and that was the rusty nails and winter condensation.
Mark Nahrgang
www.HeyMark.info
Old 10/25/09, 8:22 PM
Mark you do know that simply because for some reason you never had a problem that it is still a issue?
Old 10/25/09, 8:56 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
In the Kansas City Metro it is not a requirement. But I always write it.
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Old 10/25/09, 9:01 PM
Thanks guys, you all are thinking the same as I am.
I did in fact, mention it in my report, but not in an alarming way, but more
of an informational statement.
Steven Waskewicz
719-510-7703
Old 10/25/09, 9:08 PM
"Steven, is that two bathroom vents and one dryer vent in the smooth duct.?"
Hi Marcel, I believe its two bathroom vents and one dryer vent.
I hear you, I guess the builders are content with just up into the attic...
"Hate to see what happens with a prevailing wind, and no ridge vent. "
We have some incredibly high winds out here on the front range,
I've personally seen gusts as high as 90 - 100 mph, and anything thats not nailed down is blown south...
Very few homes actually have full ridge vents, more than likely (like this home) the soffit vents and gable vents suffice for breathing the attic.
"Why is the felt paper directly on the truss framing.?"
That is actually the back side of the fiberous type sheathing applied as the skin to this building.
"I know, I know, I ask to many questions right.?"
No problem, glad to chat...
Steven Waskewicz
719-510-7703
Old 10/25/09, 9:18 PM
Steven, thanks for the reply, and what I meant by prevailing winds, and you just enforsed it with the wind speed you get, won't this wind just blow in the exhaust ducts and force it in a reverse motion in the house when they are being used?
Just curious.
Old 10/25/09, 9:31 PM
Joe Funderburk, CMI's Avatar
You have to keep in mind that most bathroom vents are simply fart fans.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 10/25/09, 9:32 PM
Just curious.
Most exhaust fans have a back-draft damper.
Theodore Roosevelt
Joe Funderburk, CMI
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 41 4/5/12 6:43 AM
Finding bathroom vent terminations (under the insulation) kshepard Interior Inspections 26 11/5/07 5:40 PM
Soot around the bathroom vent lclark Exterior Inspections 7 3/6/06 8:13 AM
