Go Back   InterNACHI Message Board > Specific Inspection Topics > HVAC
HVAC Topics include heating, venting, and air conditioning.
Old 12/18/07, 5:22 PM
Mike M. Gauthier Mike M. Gauthier is offline
Question Black stains on FG insulation
Hey all,
I keep seeing black stains on FG insulation and need to validate what I THINK I beleive it is... (sorry no photo handy)
Common scenarios are in garages or outbuildings with VB installed but no wall or ceiling finish.
I used to think this was soot that found its way through holes and overlaps in the VB and attached to the insulation now having condensation thereon, since it was fairly common in garages with wood stoves.
Often newer similar buildings that have (or never had) combustible units (woodstoves, oil/gas furnaces).
I'm stumped... help!
Mike
Old 12/18/07, 7:12 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Default Re: Black stains on FG insulation
Without picture it is difficult to tell (sometimes with picture), but most FG insulation I find that has black stains is from moisture.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 12/19/07, 1:42 AM
The vast majority (99% +) of stains in fiberglass is "filtered dust" from air leakage through the unsealed vapour retarder and wall/attic system. Remember fiberglass is used as a filter medium on forced air systems!!
I have many pictures of this phenomenon. I tell my customers when talking about energy conservation (airsealing) and possibly saving their roof sheathing from moisture/mould /rot "to lift up the fiberglass batts and at each dark spot/line on the lower side of the fiberglass batts will be a leak of air containing moisture and heat from below" Seal it!!!
Old 12/19/07, 2:06 AM
dchew dchew is offline
The black stain marks are due to leaks in the ducting. For supply ducts, it's the venturi effect which sucks outside air into the ducting. Nothing serious, you might want to make a recommendation for duct sealing to improve the overall efficency of the system.
Old 12/19/07, 8:29 AM
cbottger's Avatar
cbottger cbottger is offline
There would be no venturi effect on round duct supply pipe it has static pressure and would be called air duct loss. On a return yes it would draw non-conditioned air into the system and yes I would consider that as serious waste of energy
CMOR Thermography Certified Level 11 #2097
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
Professional Home Inspector State License # 130
Reporting system by Home Inspector Pro
Serving the State of Okla.
Old 12/19/07, 12:14 PM
Smile Re: Black stains on FG insulation
You support my original theory. I will stick to that, now I know I'm not just dreamin this up! Thanks!!
Old 12/19/07, 12:44 PM
Roger A. Frost's Avatar
Roger A. Frost Roger A. Frost is offline
Nice to know info for insulation. Thanks for sharing, I am sure it will come up and with your information this ensures proper answer for client
Regards
Roger Frost CBCO
Barrie Home Inspector
Alliston Home Inspections
Orillia House Inspector
Barrie, ON
(705)795-8255
Black Insulation?? jlybolt Interior 23 12/24/07 4:08 PM
Vaulted Ceiling Insulation rcooke Canadian Inspectors 3 1/22/07 11:24 AM
Black stains on roof sedwards1 Exterior 4 1/5/07 11:41 AM
New Old Insulation rcooke Canadian Inspectors 1 12/13/06 6:25 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
