I cannot say i've seen it before but is this type of exhaust vent pipe ok to use in this situation? I am calling my HVAC guy tomorrow but curious what you all have to say.
Jeff Campbell Campbell Property Inspections http://www.maineshomeinspector.com Pittston, Maine NACHI04013010 |
| Need a home inspection in North Carolina? Check out InterNACHI's listing of North Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Did all joints have 3 sheet metal screws spaced equally around the pipe? Was the end entering the chimney secured by screws into a piece of pipe solidly set in mortar or was it just crimped and shoved into the chimney "thimble" opening? This is usually poorly done and not truly secure. Last edited by Brian A. MacNeish; 5/3/10 at 3:37 PM.. |
Brian,
I recommended the same on the straps... all else looked ok... In 8 years... NEVER seen the black... I am verifying the gauge... this one was set in mortar and screwed... i do have a better picture showing that... but you're right not often done that way... crimping is more common. Thanks... btw... my heating guy told me the same thing about the gauge this am... his words were..."Color is not the concern... It can be Panther Piss Purple for all I care BUT..... It needs to be 24 gauge smoke pipe to be legal.... A lot of wood stove pipe is 24 gauge but some are not..." Jeff Campbell Campbell Property Inspections http://www.maineshomeinspector.com Pittston, Maine NACHI04013010 |
Jeff, I hope you noted that exposed polystyrene on the wall. Should be covered with a non-combustible material.
Single Wall Stovepipe Single wall stovepipe is designed to connect a wood stove to a nearby chimney. It is available in different thicknesses (24 ga. or 22 ga.) and is usually painted with a high temperature black paint. Some manufacturers produce stovepipe in porcelain enamel colors to match their stoves. As a general rule (check your label and instructions), stovepipe must be kept at least 18” from any combustible wall , ceiling or furniture. This distance can be reduced in two different ways: * Protect the combustible surface with an approved method * Install a Stovepipe Heat Shield on the Stovepipe The reductions gained by these methods is usually 50% (9 inches). LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Black pipe is required for wood appliances and are heavier gauge. Galvanized piping used with wood appliances would corrode in the first year...
Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
It may not have to be 24 ga. Up here, it can be 28 ga for oil. For wood, depends on pipe diameter: less than 6"..........................26 ga 6" to less than 10".................24 ga 10" and greater than 10".........must be engineered Last edited by Brian A. MacNeish; 5/4/10 at 9:19 AM.. |
Marcel C.
that i did brotha!!! Jeff Campbell Campbell Property Inspections http://www.maineshomeinspector.com Pittston, Maine NACHI04013010 |
| Pellet stove help | chellickson | General Inspection Discussion | 23 | 8/19/10 1:23 AM |
| Is this allowed? | belliott | Plumbing Inspections | 4 | 7/15/09 6:40 PM |
| Identify ABS defective pipe | mcyr | Plumbing Inspections | 6 | 1/29/09 6:39 PM |
