I know this could be better, but technically, is there anything wrong with this set up?
Thanks, Scott Falvey Clear View Home Inspections, LLC Newbury, NH NACHI#05051292 www.clearviewhomeinspectionsllc.com |
ccbrands1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
it appears negatively pitched in 2 spots.
I would write it up as needing correction for that reason. 1 elbow would make sense here. not sure what they were trying to accomplish. |
I agree to many 90's and no pitch.
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
jhugenroth is a non-member guest and is in no way affiliated with InterNACHI or its members.
The total area when connecting multiple vents needs to be the size of the largest plus at least 50% of all others. That vent above the connection appears to be the same size as the one coming off the boiler, so it is too small for both appliances.
Also, is the single wall pipe within 2" of the sheetrock? The paper facing is considered a combustible material.
Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
Do the joints have the required bolts or are they just taped?
I like to see Wye connectors at intersections, verses the Tee connector.
The joints are taped, with cloth duct tape. Not the best job going.
I would write it up as handyman's work. The cpvc water line on the hot side should be offset because of the way the water heater was set up. The vent should be piped with one 90 to the larger vertical pipe. There should be a directional wye and the piece above this wye should be 1-1/2 -2" larger than the main vent pipe from the heating appliance.
