Rocky Ganelli is a non-member guest and is in no way affiliated with InterNACHI or its members.
what kind of routine maintenance should be done to a boiler? how often should i drain it? whats the difference between steam heat and hot water heat?
thx |
Start here: http://www.srmi.biz/Tips.Residential...ng_boilers.htm Jeff Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
All Boilers should be serviced annually at a minimum.
Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
what are the differences between a steam boiler and a hot water boiler?
Frank Newman is a non-member guest and is in no way affiliated with InterNACHI or its members.
At the risk of oversimplifing, a steam boiler produces water vapor that is circulated to the areas to be heated where heat is removed, the vapor condensed and the condensate is returned to the boiler for reheating. A hot water boiler heats water to below the temperature of conversion to steam and is circulated through the building where heat is extracted as needed. In some countries "district heating" is provided as a utility to the community with hot water being circulated to all homes much like municipal water. In that case each customer is charged for the heat extracted.
i guess what im not articulating is im looking for the differences between steam and hot water systems. both systems heat water. one system citculates steam thru the house, and the other circulates hot water thru the house. one system is sealed and the other will bleed off excess pressure/air, one does not. one system operates at a higher pressure, while the other operates at about 2psi. some have one pipe, some two. one system contains a glass tube so the level of water can be monitored, one does not. i thought you all were home inspectors here
how do i know VISUALLY which is which and what is the accompaning maintenance? |
sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
VISUALLY, steam boilers have sight glasses
Thomas Duchesneau is a non-member guest and is in no way affiliated with InterNACHI or its members.
Along with the sight glass on a steam boiler should be a low water cut-off float switch, which opens the circuit to the burner. Also, is a spring loaded momentary valve that should be opened once a month to flush any mud out of switch area (also known as blowing down the boiler).
Some steam boilers have a dual action float system which will add water when necessary in addition to being a low water safety. A hot water boiler has an auto-feed pressure regulator to keep the boiler full, with no low water cut-off. So in case of relief valve failure it is inconceivable that the boiler could drain down below the aquastat/hi limit because if you take notice, the RV is always higher than the aquastat. However, the RV usually resets as the press. drops below 30 lbs. |
| Boiler Shutdown | dkoniuk | Inspecting HVAC Systems | 2 | 8/6/07 10:34 AM |
| Boiler Control Recall | ldapkus | Inspecting HVAC Systems | 0 | 1/25/07 5:50 PM |
| Electrical Inspection Training for Home Inspectors | jtedesco1 | Inspection Education & Training | 6 | 4/27/06 11:43 PM |
| Boiler question | dmacy | Inspecting HVAC Systems | 15 | 2/22/06 11:56 PM |
| Romex on a Boiler? | mgifford | Electrical Inspections | 7 | 1/10/06 5:27 PM |
