Old 3/14/07, 11:02 PM
Charley L. Bottger's Avatar
Default Brand spanking new unit can you see a problem
This was on an inspection today brand new home never lived in can you see what I see.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 3/14/07, 11:05 PM
Ted Allen Ted Allen is offline
Default Re: Brand spanking new unit can you see a problem
Well, the disconnect does not seem to have the propper clearence.
Old 3/14/07, 11:06 PM
Roy D. Cooke, Sr's Avatar
I can not see any weep holes and the foundation does not come up high enough the bricks are touching the ground .
No vapour barrier showning under the Bricks .
Roy Cooke
Michael Larson's Avatar
Must be Bluetooth enabled for control.
Old 3/14/07, 11:08 PM
Marc D. Shunk's Avatar
Banned
No strap on AC whip. Lack of working space about AC disconnect. Missing bubble cover on receptacle. No low voltage thermostat type cable present OR thermostat cable improperly run in flex with AC wiring.
Old 3/14/07, 11:25 PM
Good eye Marc the low voltage wire was inside the seal tight with the 220-volt????
NACHI Member
State License # 130
Old 3/15/07, 12:53 AM
Brian E. Kelly's Avatar
Excellent.
Old 3/15/07, 3:06 AM
wforsyth's Avatar
wforsyth wforsyth is offline
Please Note: wforsyth is a non-member guest and is in no way affiliated with InterNACHI or its members.
Gap at penetration. Should be sealed to prevent entry by WDO's and moisture.
Old 3/15/07, 7:17 AM
staylor5's Avatar
staylor5 staylor5 is offline
Marc, isn't the "in-use" cover for pool pumps and things that are constantly on?
Old 3/15/07, 4:42 PM
Banned
Nope. Not any more.
Old 3/15/07, 9:57 PM
Bruce A. King's Avatar
Missing liquid line filter dryer....
These are on most all units around here.
(or is it just the heat pumps?)
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 3/15/07, 10:00 PM
Banned
Both, but they're factory installed on the interior of the condensing unit. Some installers choose to add an extra one and sometimes a sight glass. Heat pumps use a special filter/drier that is bidirectional.
Old 3/16/07, 8:21 AM
Marc is right some MFG install the liquid line dryers inside the cabinet but some do not. Any contractor worth his salt would install a dryer external to the cabinet if one is not provided. It is not a code issue just good common sense.
It is not recommended to install two dryers in series on any A/C unit
NACHI Member
State License # 130
Old 3/17/07, 9:31 AM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
Could not see if the lineset was passing through a pvc pipe chase. I prefer not seeing linesets installed through brick or masonary walls without one. Just the way I was trained.
Old 3/17/07, 9:43 AM
Me too, this one had PVC but a lot of contractors don't bother or don't care.
NACHI Member
State License # 130
Plumbing problem at home. mnahrgang Plumbing Inspections 25 7/10/07 5:32 PM
Central air problem clawrenson Inspecting HVAC Systems 6 6/16/07 11:19 PM
Need Assistance on A/C Unit pcarter-old-04 Inspecting HVAC Systems 9 6/21/06 7:23 AM
Adding a A/C unit abishop Inspecting HVAC Systems 20 1/18/06 1:39 PM
