Old 6/1/11, 12:44 AM
Dale Young's Avatar
Dale Young Dale Young is offline
Default A/C compressor fins?
Did an inspection today, A/C units fins were severly closed. Seller stated pressure washed them several years ago. Though about writing it up as could adversely affect the cooling unit and cause premature failure. Have qualified, HVAC evaluate and repair/replace as necessary.
Dale Young
Young & Son Home Inspection Service
601-431-3551
www.younghomeinspection.com
Need a home inspection in California? Check out InterNACHI's listing of California certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/1/11, 12:58 AM
Dale Duffy's Avatar
Default Re: A/C compressor fins?
Yep, the Coil looks "Damaged"...Pressure Washer?....hard to believe what some people do---
Inspected a building last week the Heat Pumps had severe Hail damage, but nobody tried to straighten them out with a pressure washer...may work squirting from the inside outward, but I doubt it---
Old 6/1/11, 1:35 AM
Dale Young's Avatar
Question: Can the fins be straighten out to allow enough cooling to take place?
Dale Young
601-431-3551
Old 6/1/11, 6:12 AM
Linas Dapkus's Avatar
Linas Dapkus Linas Dapkus is offline
Absolutely. Simply replace the unit.
Old 6/1/11, 6:31 AM
rramsey1 rramsey1 is offline
Please Note: rramsey1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Tedious job. Lots of cut fingers. Yes, the fins can be straightened out with "Fin combs, needle nose pliers and ice pick. Very expensive to have a technician do this task though
Old 6/1/11, 8:10 AM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
Depends on how damaged. If they are just flattened a fin comb should take care of most of them. If some are doubled over it may take fin comb, pocket screwdriver a radiator fin pliers. It is going to take time. Yes it will cost but it will reduce compressor run times and lower amp draw.
Old 6/1/11, 8:43 AM
Charley L. Bottger's Avatar
Strange that you should make this post when you did. I received a call yesterday about the same subject HI failed to report hail damage on a inspection 2 units probably going to cost him some money
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 6/2/11, 4:09 PM
Robert J. OConnor's Avatar
... A/C units fins were severly closed ... Though about writing it up as could adversely affect the cooling unit and cause premature failure.
Absolutely ... restriction of the air flow will limit how well the unit can cool the freon gas. The system won't cool the house as well, and it could run continuously on hot/humid days, eventually leading to an early death for the compressor.
Originally Posted by dduffy View Post
... nobody tried to straighten them out with a pressure washer ... may work squirting from the inside outward -
Funny stuff ... Hmmm ... may be worth a shot for the guy to "fix" the damage ...
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
