I always call-out a A/C condensate line that drain directly into the plumbing system (no air gap) even if a p-trap in the line is provided, over here that p-trap will dry out during the winter, am I calling this right ? would the same apply to furnace condensate line
All modern installations in my area will drain to the tailpiece of a sink drain or laundry drain. What makes you think this is improper?
I don't think I've ever seen a furnace that produces condensation. . . IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I am in north Ontario A/C are 95% install on force air furnace and if the condensate line is install direct to the sewer pipe it could draw sewer gas .In this area high efficiency furnace have condensation line that goes to a drain of some kind.
Jeannot |
Typically the condensate drains to a condensate pump and that pumps it up and into an airgapped drain line. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
If the condensate line is plumbed to a sink tail piece I do not call it out as the sink will most likely have water in the trap. Same if it is plumbed to the washer drain. Now if it is plumbed to a trap that you think will go dry, by all means call it out. If it is plumbed into a waste vent I always call those out. |
Thanks for your comment, that's what I thought. I wonder why HVAC technicians keep installing them directly in the sewer line
I call a waste vent, a vent. And a drain a drain. Usually it is an easy call because HVAC guys make lousy plumbers.
ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 8/26/08 at 3:41 AM.. |
If I am not mistaken a 95% efficient furnace the condensate comes from the flue exhaust. Which would mean that if the trap ran dry sewer would not enter the attic or the furnace air stream, I would be ok with it. |
I have run across another's one today, a/c had a p-trap in the line but was connected directly to sewer line. This summer here in northern Ontario a/c might have run two days that p-trap will spent most of the year dry. Worst the H.R.V. condensate line was connected directly no p-trap.
| condensate drain to sewer line?? | wcook2 | Inspecting HVAC Systems | 5 | 5/1/08 9:27 AM |
| 1 condensate line...... | Scott Schultz | Inspecting HVAC Systems | 2 | 11/4/07 6:18 AM |
| Condensate line. | jlybolt | Inspecting HVAC Systems | 10 | 3/21/07 9:05 PM |
| TPRV line and condensate line marriage | ccarrington | Plumbing Inspections | 3 | 4/29/06 7:59 AM |
