I'm just starting out. Can anyone tell me if there is a sure (easy) way to tell if a heat pump is installed?
| Need a home inspection in Hawaii? Check out InterNACHI's listing of Hawaii certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Jim Look at the condenser and look for the Reversing valve, and likley the thermostat will give you a hint.
Maybe take the nachi Course http://www.nachi.org/hvaccourse.htm Last edited by wwilson3; 2/12/10 at 3:41 PM.. |
In our climate the heat pump is always up off the ground to accomodate dripping and ice underneath. Also to keep it above the snow. They are typically about 1 foot off the ground on a stand.
Keith Runquist, CMI |
Thanks Wayne. Very helpful. I will take the course. And thanks for the photo.
Thanks as well Keith another very useful bit of info.
Chuck Lambert is a non-member guest and is in no way affiliated with InterNACHI or its members.
The id tag usually states 'Heat Pump'
Running the heat, the condenser will be running.
Thermostat will have an "emergency" or "auxiliary" heat mode. Caveat: some heat pumps have been incorrectly installed with a traditional thermostat, and that would be wrong. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
kluce is a non-member guest and is in no way affiliated with InterNACHI or its members.
Another indication is three ports to hook up the Freon gauges.
Where are you from? |
http://www.midtninspections.com/blog?page=2
They all don't note "Heat Pump" on the data plate. Thermostat should have an emergency/axillary heat option (but don't bank on it)! Not all three ports are visible without pulling the unit apart. Running in heat may not energize the outdoor unit (there is no condenser on a heat pump). There is not always an accumulator. As Wayne posted, look into the fan grill and look for the reversing valve. That is the only sure way. We use "refrigerant gauges", Freon is a manufacturer not the gas in the unit. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission Last edited by dandersen; 2/13/10 at 3:16 PM.. |
Air conditioning for residential is not an exact science and many methods I've seen used (that are a lot faster) puts those freon level and temperature drop right in that range. The guy wants to be able to identify a heat pump. I think the suggestions we gave him are a great start to help him with his learning curve. |
I found this real quick. You can see the third port on the housing above and middle of the two freon lines.
In most cases, the third connection is accessible so the service tech or installer can hook that Freon hose to it. You might have to take off that service panel to see it. |
Quickest thing is looking for the reversing valve it has been a rare event not seeing one.
BTW Try touching the suction line ( bigger line) if it is hot it is a heat pump ( if it is running that is ) |
Maybe you can use the temp drop in your neck of the woods, but humidity (which is latent heat) throws that stuff right out the window in many parts of the country. You just do what you think is right for you. As nowhere in any SOP is HVAC diagnostics part of Home Inspection, I think the new guys should think long and hard about it. Most HI Law Suits are about HVAC stuff. The temp drop works when the HVAC systems are deigned correctly in the first place. But a HI has no idea if this is the case. At what friction loss do you design your HVAC systems? How do you test for friction loss? If this is not set up correctly, a thermometer tells you nothing. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
[QUOTE]It's been a while since I did heating and cooling but if I remember correctly, there was a +/- 3 psi when charging using the super heat method.
O-well, It's 6pm and I got to get out of the office now and get home so my wife and I can enjoy a night out without the kids. Good night all. |
| Radiant ceiling heat? | bmargiotti | Inspecting HVAC Systems | 16 | 1/24/12 11:46 AM |
| Heat pump in a 80+ year old masonry house | jskrypka | Inspecting HVAC Systems | 9 | 11/25/06 11:47 PM |
| Question on my heat pump | dbush | Inspecting HVAC Systems | 7 | 3/12/06 1:15 AM |
| Heat Pump Check list for inspecting | dmacy | Inspecting HVAC Systems | 21 | 2/1/06 1:56 PM |
