Go Back   InterNACHI Message Board > Specific Inspection Topics > HVAC
HVAC Topics include heating, venting, and air conditioning.
LinkBack Thread Tools Display Modes
Old 9/8/08, 11:33 AM
Andrew Cox Andrew Cox is offline
Andrew Cox is well trusted Andrew Cox is well trusted Andrew Cox is well trusted
Default A/C power supply
I have always assumed there is supposed to be a disconnect within reach of the outdoor unit, as a safety issue. On this house I inspected yesterday, there isn't one, it is hard-wired into the home, and the only breaker is the one inside the panel.
This is the first time I've come across this. Isn't there a requirement for this to have a disconnect close-by? And as this buyer will be financing with FHA, would this be something the FHA inspector would call out? Thanks.
Andy Cox
http://www.CoxInspections.com
Kissimmee, FL
You’re Your Own Job Security.
Old 9/8/08, 11:54 AM
Jeffrey R. Pope's Avatar
Jeffrey R. Pope .
Default Re: A/C power supply
The panel-breaker can be used as the disconnect, as long as it is within sight of the appliance.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
http://www.MyInspector.net
Old 9/8/08, 12:03 PM
Jeff, thanks. However, there is no breaker for it within sight. This is outside, and the panel breaker is inside the garage.
Andy Cox
Kissimmee, FL
Old 9/8/08, 12:32 PM
Jeffrey R. Pope .
Then it needs to be corrected. There must be a disconnect within sight of the appliance.
It's very unlikely that the FHA inspector will recognize this issue, but you should report it as a defect.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 9/8/08, 12:45 PM
Thanks Jeff.
I've already written it into my report and showed it to the client during the inspection. It's a bank-owned property, so she'll pay for it anyway, but I'll recommend it be repaired immediately.
Andy Cox
Kissimmee, FL
Old 9/8/08, 1:33 PM
David A. Andersen's Avatar
David A. Andersen .
You assumed right, but you should never assume.
ITC Certified Infrared Thermographer Cert#1958
http://thermalimagingscan.com
Old 9/8/08, 1:36 PM
John Allingham John Allingham is online now
John Allingham is generally well trusted John Allingham is generally well trusted
Hi Andrew
I quite often see older A/C units with no disconnect in sight . It wasn't in the code back then.
If this is an older installation you may want to check that out.
Old 9/8/08, 1:48 PM
David A. Andersen .
If you look at the picture of the building and the HVAC, it is quite obvious that an HVAC disconnect was required at the time of construction.
It really doesn't matter if it was building code at any time because it's not our job to interpret or enforce these building codes.
We are here to simply report there is no disconnect at the outside unit and it can kill your HVAC technician if he can't turn the power off!
Old 9/8/08, 2:05 PM
Jeffrey R. Pope .
Originally Posted by jallingham
Hi Andrew
This may be true for Canada - I don't know Canadian Codes.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 9/8/08, 2:48 PM
Charles L. Harper Charles L. Harper is offline
Charles L. Harper is generally well trusted
Hey Jeff,
I saw your response concerning an ac disconnect. I had the same issue this morning. AC units were hardwired into main disconnect on outside of house. SO if you have to disconnect the ac unit for any reason than you will also shut off ALL power to the home. This doesn't seem right.
www.HomeInspectionGA.com
McDonough, GA.
770-954-0204
Old 9/8/08, 3:26 PM
Jeffrey R. Pope .
Well, the "required disconnect" is effectively in place, however, there are rarely any instances where the direct tap would be compliant, regardless of the equipment it serves.
It certainly isn't the most preferred method, however, if wired properly and not double-tapped, it may well be compliant.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 9/8/08, 3:30 PM
Jeffrey R. Pope .
Actually, I think I may have given a bit of misinformation.
In your case, the service disconnect for the house must not exceed the maximum circuit rating for the condenser unit(s). So it's very unlikely that what you had was compliant.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 9/8/08, 8:46 PM
Jeff, you are 100% correct. Why I didn't think of that I don't know. This particular builder has done all of the houses in this sub division like this.
McDonough, GA.
770-954-0204
Old 9/8/08, 8:56 PM
Terry B. Clayton Terry B. Clayton is offline
Terry B. Clayton is generally well trusted
The only way I know this would pass would be if the interior disconnecting devise is capable of being locked out by the servicing tech. Hope they never have to replace the sealtite
Old 9/8/08, 9:01 PM
Brian K. Doles's Avatar
Brian K. Doles Brian K. Doles is offline
Brian K. Doles has a reputation beyond repute Brian K. Doles has a reputation beyond repute Brian K. Doles has a reputation beyond repute Brian K. Doles has a reputation beyond repute Brian K. Doles has a reputation beyond repute Brian K. Doles has a reputation beyond repute Brian K. Doles has a reputation beyond repute Brian K. Doles has a reputation beyond repute Brian K. Doles has a reputation beyond repute Brian K. Doles has a reputation beyond repute Brian K. Doles has a reputation beyond repute
To help educate me, what makes this so obvious in the picture?
Brian K Doles
Atlanta, GA - Providing Infrared Thermal Home Inspections
Home Inspections
Commercial Inspections
Infrared Thermal Imaging
Colby Home Services
All of metro Atlanta including Conyers, Covington, Stone Mountain, Midtown, Buckhead, Perimeter
Customer Testimonials
Home Inspector Pro Software - A Professionals choice in software.
Display Modes
Power Supply to Subpanel Mick D. Jones Electrical 6 8/27/08 5:55 PM
Help. What is the correct way to report a breaker that is too big. gromicko Electrical 72 3/12/08 12:19 AM
Selected Electrical Incidents and Occurrences - First Quarter pabernathy Electrical 0 12/2/07 2:43 PM
supply in slab or walls? jeubank Plumbing 1 7/8/06 11:36 AM
Emergency Lighting (commercial) mcyr Electrical 24 6/10/06 11:06 AM
Popular
Membership
Education
Chapters & Members
