Old 8/10/06, 9:42 PM
Bill@MyMagicCity.net Bill@MyMagicCity.net is offline
Please Note: Bill@MyMagicCity.net is a non-member guest and is in no way affiliated with InterNACHI or its members.
Question A/C refrigerant lines
Can somebody give me some insight on gurgling refrigerant lines on new construction Goodman heat pump?
Thanks for any advice. BC
Old 8/11/06, 12:20 AM
David A. Andersen's Avatar
Default Re: A/C refrigerant lines
That is common on Goodman units.
The sound is from the restrictor piston at the evaporator coil.
This can be an indication of a low refrigerant charge.
If all else functions, I would let it go.
Grab the suction line. If it is cool-cold to the touch, there is likely sufficient refrigerant charge.
Gas supply lines to water heaters. dkoehl Plumbing Inspections 5 3/6/11 3:07 AM
Ice on refrigerant lines at compressor. jmerritt1 Inspecting HVAC Systems 7 6/9/07 9:22 PM
Refrigerant Lines bking Inspecting HVAC Systems 30 7/17/06 9:51 AM
