I did an inspection today. My question is, can you wire a A/C unit striaght to the service panle breaker? It is not doubled tap either.
tneumann is a non-member guest and is in no way affiliated with InterNACHI or its members.
Is the service panel in sight and not more than 50? ft away? Dedicated circuit?
I don't know for sure either..other than what i wrote above..... |
The panel is in sight, about 6 ft. away
The panel you are referring to is LSE (Sub panel). Yes, this should be wired directly. Make sure the breaker is appropriately sized.
Huh? You have ESP and XRay vision?
He may or may not be talking about the main service panel eh? Barron, is best to take a pic.... Last edited by tneumann; 2/8/06 at 8:13 AM.. |
in ohio a service disconect must be with in arms length
In most jurisdictions, it doesn't matter how the disconnect is provided (service panel, load-side panel, switch, breaker, pull-out, etc.) so long as it is in-line-of-sight from the equipment/appliance. Some jurisdictions specify the distance, in addition to the location, but I've never seen "arms length" in a code reference. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
It's an AHJ thing...and you know how they are. If they don't know the code they say "arm's length". "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
Ohio use the IBC and IRC?
The IRC says. . . Quote:
| question on wireing furnace, legal or not | Bill Hathaway | Electrical Inspections | 26 | 1/19/07 10:36 PM |
