Go Back   InterNACHI Message Board > Specific Inspection Topics > HVAC
HVAC Topics include heating, venting, and air conditioning.
Old 4/16/07, 10:51 AM
Bruce M. Graham, III's Avatar
Bruce M. Graham, III Bruce M. Graham, III is online now
Default Can you id the problem?
How long will this compressor last?
Bungalows to Mansions
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 4/16/07, 11:30 AM
Michael Larson's Avatar
Default Re: Can you id the problem?
What is the 1/2 white PVC for.
Old 4/16/07, 11:50 AM
Thats how they run condensate down here. most of the time it is run under the slab and comes up about 12" from the house.
Bruce M. Graham III
352 871 8989
NACHI05091592
ICC 5268478
Old 4/16/07, 12:11 PM
David P. Valley's Avatar
I would simply recommend that all condenser piping be exposed to avoid any issues later. That means that the HVAC contractor must return to the site and correct his poor workmanship.
Who in their right mind would purposely bend the piping in order to bury it?
Old 4/16/07, 12:13 PM
Does that condensate line come out of the building and into the ground and then back up again next to the Condenser?
Old 4/16/07, 12:20 PM
That's what I am wondering. Is it pump assisted?
Old 4/16/07, 2:45 PM
Rick McCullough Rick McCullough is offline
I can't tell,, it's all buried.
Old 4/16/07, 6:44 PM
Kenneth Lott's Avatar
Kenneth Lott Kenneth Lott is offline
About as long as that siding.
Old 4/16/07, 6:59 PM
jlyvers's Avatar
jlyvers jlyvers is offline
Where does the compressor get its power? Is that underground too?
Joe Lyvers
Gulf Breeze, Florida
NACHI04040881
Old 4/16/07, 9:30 PM
William E. Siegel William E. Siegel is online now
Ill bet you that thing will back up pretty soon. The termination point looks pretty high.
Also (I am assuming that is new costruction) what happens when they put sod down. Now the pad is not the requried 3 inches above finished grade.
Bill Siegel
Florida Home Inspection Team Inc.
Old 4/16/07, 9:46 PM
Well, the air handler is in the attic which adds to the problem.
Bruce M. Graham III
352 871 8989
NACHI05091592
ICC 5268478
Old 4/16/07, 10:54 PM
cbottger's Avatar
cbottger cbottger is offline
Yes sir I see more than most you are going to be having an oil return problem as this line is creating an oil trap we also do our condensate lines similar but not under the slab
</IMG></IMG>
CMOR Thermography Certified Level 11 #2097
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
Professional Home Inspector State License # 130
Reporting system by Home Inspector Pro
Serving the State of Okla.
Old 4/16/07, 11:01 PM
cbottger's Avatar
Mike A-coil in the attic the condensate line is just an oversized P-trap has to flow
NACHI Member
Old 4/16/07, 11:05 PM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
Slowly back away. This install may snarl and attack you.
Which code haven't they ignored. No electrical disconnect? Let me guess they drip leg the drain close to the condenser for evaporative cooling increasing cooling capacity by another 200 btuhr. Lineset and thermostat wiring buried????
Old 4/16/07, 11:28 PM
Well Duh.
Thanks Charley, living in the land of basements I just never think of attic mounted units.
Fetch Report problem mhazelwood Misc. Discussion 7 11/12/07 12:12 PM
Is MAC a problem bemelander General Inspection Discussion 2 9/6/07 12:34 PM
Camera Problem nwagner Misc. Discussion 19 7/30/07 11:10 PM
Plumbing problem at home. mnahrgang Plumbing 25 7/10/07 6:32 PM
Very tough problem Albert Detorre HVAC 7 2/23/07 1:01 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
