Old 1/23/08, 4:32 PM
mkiss1 mkiss1 is offline
Default Carrier 8000TS
Hi guys,
Does anyone have a copy of Preston Guide or Dunlap. I'm looking for information on Carrier Weathermaker 8000TS Yr. 2001. What's the SEER on it? Also, what's the max. output. Is it 80,000 BTU? Just want to make sure. Thanks!
Old 1/25/08, 6:27 PM
Default Re: Carrier 8000TS
I got the serial number: 0902E06184 (on the condenser outside). I hope it helps to get more info. Thanks!
Old 1/25/08, 9:44 PM
lfoster's Avatar
lfoster lfoster is offline
Go to www.carrier.com and work through their site. Usually can find what you need.
Old 1/25/08, 11:34 PM
wsiegel wsiegel is offline
The model number will give you the tonage. Being a 2001, unless is it is a high efficiency, it is probably a 12 SEER. 13 SEER wasnt required until 2006
Carrier Recall bwiley Inspecting HVAC Systems 0 11/8/07 9:33 AM
Age of Carrier unit? pcoulter Inspecting HVAC Systems 3 11/5/07 10:17 AM
Red "Check" light on Carrier Thermostat Skip Erwin Inspecting HVAC Systems 10 12/29/06 6:50 PM
Carrier heat pump fires? lprinzi Inspecting HVAC Systems 3 10/12/06 8:31 PM
Carrier Heat Pump phinsperger Inspecting HVAC Systems 5 3/24/06 9:21 PM
