Old 5/3/07, 1:43 PM
William J. Decker's Avatar
Default Cat 4 furnace verbiage
Can anyone give some verbiage on this issue.
Rheem 2005 sealed combustion cat 4 furnace installed in an attic room. The combustion intake air vent was open to the attic, not taken outside.
Buyer talked to the village code people and theu said it was OK.
I was always informed that Cat 4 sealed furnaces should take their air from outside.
The attic room had 2 vents to the attic.
Comments to support my arguement?
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 5/3/07, 9:03 PM
Charley L. Bottger's Avatar
Default Re: Cat 4 furnace verbiage
Cannot support you Buddy they are not required exterior to the home in my area just inspected one this week made its turn right in the middle of the attic space. Would be a different story if the attic was sealed but with a vented attic what is the difference. We have been taking combustion air from attics on other furnaces for a hundred years why not this one.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 5/3/07, 9:44 PM
mthomas2 mthomas2 is offline
If a CAT IV furnace has *both* a combustion vent pipe *and* a combustion air intake pipe, every installation instructions I've seen require that the termination of *both* pipes be in the same atmospheric pressure zone. If the combustion air intake pipe (connected directly to the furnace) terminates in the attic, and the combustion vent pipe is venting to the exterior, they are not. (Note that this is NOT the same as the same furnace drawing combustion air from a utility closet drawing combustion air from the attic.)
Old 5/3/07, 10:04 PM
Matt Berman Matt Berman is offline
Wink Re: Cat 4 furnace verbiage
There are some cat 4 furnace mfgr that allow you to pull combustion air from the surrounding space as long as it is not a confined space. York is one i can think of.Matt
Old 5/3/07, 10:08 PM
Lightbulb Re: Cat 4 furnace verbiage
Read installation instructions,they should be at or near furnace area .Matt
Old 5/3/07, 11:11 PM
For an example, see item 2 at the top of page 11 (document page number, shows up as page 17 in my Adobe reader) here:
http://www.thermopride.com/manuals/mg1010.pdf
An attic is not in the same "atmospheric pressure zone" as an exterior location as wind forces will often be produce pressure differences between the inside and outside of the attic. Again, note that this applies only to the situation where the furnace is drawing combustion air via direct connection to an intake pipe, not to an arrangement in which the furnace is drawing its combustion air from a utility closet with a properly sized connections to a vented attic.
Old 5/4/07, 1:03 AM
So Is American Standard
NACHI Member
State License # 130
Old 5/4/07, 11:26 PM
Thanks, Mike.
Client is lawyer and the sellers are very defensive.
Never allow the local AHJ to determine what is right. They are (usually) less informed than the local HVAC guys. No CE requirements.
Will Decker, CMI
Old 5/6/07, 11:13 AM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
What do the furnace's installation instructions say? Though village codes say it may be alright if the installation instructions require a combustion air pipe outside of the structure then one will have to be installed.
Furnace Problem Comments Welcome rfrost Inspecting HVAC Systems 24 10/21/07 7:26 PM
To hot too test the furnace rcooke Canadian Inspectors 1 8/19/07 11:44 PM
Sweating decision:Settle for lower SEER to use existing furnace? Fel Randolph Inspecting HVAC Systems 2 6/6/07 3:56 PM
Armstrong Ultra 80 Oil Forced air furnace Stephen Frazer Inspecting HVAC Systems 19 4/9/07 9:00 PM
Condemned Furnaces Spark Safety Issues Gary Reecher Inspecting HVAC Systems 7 3/8/07 9:17 PM
