Old 10/12/08, 6:44 PM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default What causes this?
Got corrosion?
Old 10/12/08, 7:10 PM
cduphily's Avatar
cduphily cduphily is offline
Please Note: cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: What causes this?
Got High Humidity?
Old 10/12/08, 7:16 PM
rmaday's Avatar
Originally Posted by cduphily View Post
Got High Humidity?
Thanks.
I guess a better question is do you see anything in the pictures that would be a contributing (and correctable) factor.
No, the condensate line didn't appear to be leaking.
Old 10/12/08, 7:21 PM
Jeffrey R. Jonas's Avatar
Originally Posted by rmaday View Post
Thanks.
Nope... looks like everyday excessive moisture to me.
Guess my question would be why?
Old 10/12/08, 7:30 PM
cduphily's Avatar
Thanks.
I assume the humidifier (above the BIP in photo #2) is NOT leaking ... bad float/small crack in the jacket, did you check the feed for the humidifier? Be it a flare, commpression fitting possible small leak you may have overlooked? is this space conditioned? dehumidifier installed? Tough to tell without being there. (overstating the obvious)
Old 10/13/08, 9:31 AM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
Could have been the piping was sprayed with a gas leak detection solution and was not cleaned off.
Old 10/13/08, 10:02 AM
David A. Andersen's Avatar
Don't I see a drip on the bottom left of the union? both pic# 1 & 3.
Induced draft leak? Or other leak from above.
BPI# 5015804
Old 10/13/08, 6:04 PM
Brian E. Kelly's Avatar
Chemical storage (chlorine) nearby?
Old piping used for drip leg and short leg?
Wire brush the rust off and paint it.
Old 10/14/08, 8:44 AM
That looks like standard galvanized pipe. Anywhere that I have worked that gas has been common, only black iron pipe or copper were allowed. Is that standard galvanized?
Abraham Lincoln
Old 10/17/08, 11:08 AM
I'm going to guess higher humidity than recommended (why?), and/or possible stored corrosive agent, and/or possibly leaking corrosive condensate (past or present) leaking onto the piping. I don't see combustion design provisions in the pics. This could be a contributing/possible culprit.
Let us know what you finally determine, after further inspection by a Prof. HVAC Contr.
Old 10/17/08, 7:29 PM
sparksnmore sparksnmore is offline
Please Note: sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
Looks like black pipe and someone didn't clean off the leak detector solution.
Old 10/17/08, 7:32 PM
Oops, sorry, I see Gary already said that.
It IS black pipe.
Old 10/19/08, 11:19 AM
not a problem with the gas pipe, but is the condensate line traped?
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
