Is the change in furnace flue diameter from smaller to larger ok and is this metal duct tape oik for the transition? it seems i remember that the pipe can only be attached with screws?
Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
| Find an InterNACHI certified Nebraska Home Inspector (and anywhere else in North America) |
BUMP
It doesn't look proper. And it looks too close to combustibles where it penetrates the roof sheathing.
The second image is too blurry for me. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
so is going from a smaller to larger flue diameter ok to be made with metal tape?
The transition joint in the attic chimney pipe (from smaller to larger) does not appear proper and the chimney pipe is too close to combustible at the roof penetration. Recommend repairs, as needed for safe operation, by qualified professional.
thanks Larry.
| What's Inside A Chimney | mcyr | Inspecting HVAC Systems | 14 | 9/17/08 6:11 PM |
| Flue Size when size matters? | msylvester | Inspecting HVAC Systems | 14 | 1/20/07 11:29 PM |
| Gas Log Flue venting height. | lagudo | Inspecting HVAC Systems | 34 | 4/7/06 1:42 AM |
