Is it me or is the condensing unit twice the size of the air handler? and dumb question do you think thats a little excessive if thats the case?
| Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Just curious.
What makes you think that it is twice the size? Greg Bell Titusville, Fl 02111507 Serving Central Florida
The compressor is a 3 1/2 - 4 ton and the air handler appears to be a 2 ton. I was taught the blower on the air handler should be a half ton bigger or equal to the compressor size. I do not see how it would keep the A-coil from freezing up. Does not make sense to me. Maybe David will come along and give us his input.
Looks like a 4 ton condenser on a 2 ton E-coil. Seems like an unusual combination. Only Rheem can tell you if the two are appropriate to be paired together.
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
I only ask because it looks like a 3 ton unit from the info on the data plate. Greg Bell Titusville, Fl 02111507 Serving Central Florida
Red numbers typically show the approx BTU/H rating in 1,000s http://www.furnacecompare.com/air-co...APA-049JA.html Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
http://www.inspectapedia.com/aircond/aircond03.htm Thanks Greg Bell Titusville, Fl 02111507 Serving Central Florida
I would suspect that this unit is closer to 4 ton than 3, but even at 3 it is still a mismatch. Good catch, assuming they only had one unit.
Bungalows to Mansions Professional Inspection Services, LLC dba 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
prichardson is a non-member guest and is in no way affiliated with InterNACHI or its members.
Go to ahridirectory.org and put in the model numbers. It will tell you if they are compatible.
Here is a hint. Don't put in the complete model number. Put in about half and it will pull up a list. |
Christopher Currins Certified, Licensed Proudly serving the Illinois Metro-East Illinois Home Inspector Top 5 Tasks for January |
Kenneth,
Thanks for the thread It was very educational. I know that Gerry would have loved it. Greg Bell Titusville, Fl 02111507 Serving Central Florida
measter is a non-member guest and is in no way affiliated with InterNACHI or its members.
44,500 Btu/hr; and this unit should be paired with a RBHK-24+RCGJ-60A1 coil. All the information you need - and none of it available from the nameplate. Dividing 49 by 12 wasn't the answer. Dividing the RLA by 5 was pretty close. But how do we know we shouldn't have divided by 6, or 7? And the 24 in the coil doesn't imply 2 tons . . . So I guess we learned that we need to check out those weird model numbers. V/R Mark |
Thank you for that link Mr.Richardson.I am just starting my advanced HVAC course through INACHI.
| What's Inside A Chimney | mcyr | Inspecting HVAC Systems | 14 | 9/17/08 7:11 PM |
| NACHI TV got a check for $100,000.00 today! | gromicko | Miscellaneous Discussion for Inspectors | 15 | 12/9/06 11:45 AM |
| Electrical Inspection Training for Home Inspectors | jtedesco1 | Inspection Education & Training | 6 | 4/27/06 11:43 PM |
