Today I did a warranty inspection on a new home that had a tankless water heater that supplied hot water for domestic use and also to an air handler for home heating.
Between the two A/C lines going to the evaporator was a thingy identified as a check valve and some very small diameter tubing. Could someone please explain this to me. Thanks. |
![]() More Info Here You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Troy Farmer Presidential Inspections LLC Chapter President Southern Idaho PO Box 2144 Eagle, Idaho 83616 208-573-5300 http://www.presidentialinspection.com http://info@presidentialinspection.com "He who can, does. He who can’t, teaches" "Where would we be without Teachers" |
No check valve there, TXV is externally equalized, don't see that much on residential. check this out. http://www.hvacmechanic.com/txv.htm
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Someone installed that expansion valve with a pair of channel locks the liquid line is not the same size as the inlet to the expansion valve it has been crimped down. They either installed the wrong size valve or the wrong size liquid line
Thanks fellas.
Why don't I see the expansion valve on a regular basis. Is it usually inside the ducting? |
| Check valve first time for everything????? | cbottger | Plumbing Inspections | 5 | 4/8/07 1:43 AM |
| Backwater valve in new homes? | ccrooker | Canadian Inspectors | 16 | 11/28/06 7:47 AM |
| Pool inspections/ valve check | dbucknavich | Ancillary Inspection Services & Additional Topics | 1 | 6/21/06 3:33 PM |
