Old 7/25/07, 10:06 PM
Kerri L. Grabowski Kerri L. Grabowski is offline
Default Clearances for pellet stove
Are there any special clearances for a pellet stove? Are they the same or similar as a wood stove?
Anyone care to shed some light?
Kerri
Old 7/25/07, 10:14 PM
Charley L. Bottger's Avatar
Default Re: Clearances for pellet stove
Kerri
The MFG should have the clearances listed in the installation manual but I would think very similar to other wood burners
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 7/25/07, 10:52 PM
Banned
Clearances for all uncertified wood burners are the same but each certified stove has its own set of clearances as determined by testing at its highest firing rate. Pellet stove clearances to combustibles are usually a fair bit less than regular wood stoves Check in the manual or for a lable on the stove.
Old 7/26/07, 9:41 AM
Mark R. Long's Avatar
Mark R. Long Mark R. Long is offline
Kerri
I sold & installed pellet stoves when I was operating my retail store in a previous life. Although the pellets typically are a wood product (but sometimes corn) pellet stoves are not quite the same animal as a conventional wood stove. They normally require less clearance than a conventional wood stove. 1" on the rear and 6" on the sides is typical, but different models and different manufacturers may have variations. Except for the very front portions of the the top and sides, where they approach the front door, you can usually place your hand on the sides and top of the stove without burning it. They are engineered so that all of the heat is concentrated at the front. And overall, they usually produce a less intense heat than a typical wood stove. The heat is more moderate and constant.
Of course, as the others have said above, check with the manufacturer's installation manual for the particular model, or there may be a sticker on the rear of the stove.
If info isn't available, many manufacturers have manuals on their web sites. Here's some prominent manufacturers. http://www.quadrafire.com/index.asp . http://www.envirofire.biz/ . http://www.harmanstoves.com/ .
Mark
MD HI Lic # 30090
BPI Certified Building Analyst
PA DEP Radon Cert # 2457
Certified Home Energy Tune-uP Inspector
Old 7/26/07, 10:03 AM
Unmoderated Guest
According to the International Residential Code, the code that applies to stoves is the manufacturer's printed recommendations. Those are, as was said, developed under testing, and listed in the Installation Manual for each product. There is no one set of clearances that applies generally to all stoves.
Old 11/6/07, 9:32 AM
David Tarter David Tarter is offline
Please Note: David Tarter is a non-member guest and is in no way affiliated with InterNACHI or its members.
pellet stoves need quality wood pellets
As for clearances for a pellet stove you can ask your local distributor
Pellet Stove jmichalski Inspecting HVAC Systems 8 6/23/08 1:43 PM
Reference for clearances dmacy General Inspection Discussion 6 11/8/07 11:58 AM
Exterior Service Disconnect Clearances? rcramer Electrical Inspections 18 7/28/07 2:12 PM
Wood stove tneumann Inspecting HVAC Systems 11 5/4/06 1:18 PM
Gas log stove sfalvey Interior Inspections 8 2/16/06 10:48 AM
