Old 1/9/11, 11:01 AM
Aaron D. Miller's Avatar
Aaron D. Miller Aaron D. Miller is offline
Send a message via ICQ to amiller
Default Clothes Dryer Vent
Client's daughter has 2007 townhome where clothes dryer top gets hot and does not dry clothes. She had the vent professionally cleaned and they found no obstructions. Builder (of course) says that it was installed properly. They want me to take a peek and perform miracles. My idea is to run the dryer and use the IR camera to try and trace the length of the vent in the wall. Any better ideas?
Need a home inspection in Vermont? Check out InterNACHI's listing of Vermont certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/9/11, 11:13 AM
Russell J. Hensel's Avatar
Russell J. Hensel Russell J. Hensel is offline
Default Re: Clothes Dryer Vent
It seems to be a way to cure, but I will still bet that there is an obstruction. Maybe they looked at the dryer vent and not the Dryer itself. Maybe clogged at the rear of the dryer. I would go to a dryer that is somewhat similar and take a reading with the IR at the exhaust of an operational dryer and then one at hers to see if the temps are similar. Just because someone says its right, Does not make it right.
Has this been going on since day one or gradually started?
Comprehensive Building Consultants
Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection.
Donate here:
or send checks to the
Fl Home and Insurance Inspector Chapter
1103 W Hibiscus Blvd Ste 311
Melbourne, Fl 32901
Old 1/9/11, 11:19 AM
Has the dryer itself been checked...blockage, thermostat other mechanical problem?
Your IR idea is good.
Larry Kage, CMI
231 929 3525
Old 1/9/11, 11:27 AM
Curtis M. Vilt's Avatar
Curtis M. Vilt Curtis M. Vilt is offline
How long is the run? How many elbows? Then check the manual of the dryer. I'm sure you checked but have seen this as the cause on a few.
Old 1/9/11, 11:29 AM
She reports it has always been this way.
Old 1/9/11, 11:30 AM
Michael Larson's Avatar
If it is safe to do so, disconnect the vent system and vent it into the room as a short term test of performance to see if the dryer still gets hot.
Michael Larson
Hudson, WI
Old 1/9/11, 11:35 AM
She reports that the dryer does dry clothes with the vent disconnected.
Old 1/9/11, 11:44 AM
Then there must be an obstuction.
If you are lucky it will show up with the thermal scan depending how the pipe runs.
Make sure the termination fitting is sized correctly for the pipe length as well.
Sometimes too small a outlet is used restricting flow.
The louvered ones seem to work best as long as the mechanism keeps operating.
Michael Larson
Hudson, WI
Old 1/9/11, 12:21 PM
If that is true, then it would seem to be the vent pipe length or an obstruction issue. Get make and model and check installation instructions.
Larry Kage, CMI
231 929 3525
Old 1/9/11, 12:22 PM
I think I heard that before.
Old 1/9/11, 12:39 PM
I seem to remember that
Michael Larson
Hudson, WI
Old 1/9/11, 1:05 PM
Jeffrey R. Jonas's Avatar
May sound far-fetched, but try cleaning/scrubbing the lint filter trap. The residues from fabric softeners build up and actually create a blockage. This should be done every month, primarily to lessen a lint fire hazard.
http://www.ehow.com/how_5389332_clea...fficiency.html
Old 3/18/11, 11:24 AM
Nanci Hagarty Nanci Hagarty is offline
Aaron, were you able to detect the vent run with ir?
Nanci Hagarty
http://www.mrdryervent.com
mrdryervent@comcast.net
Phone : 610-399-3638
Old 3/18/11, 11:57 AM
Yes, I was.
Old 3/23/11, 11:25 AM
Jim Hime Jim Hime is offline
What was the end result after you inspected?
Mr. Dryer Vent / Clean, Repair, Install nhagarty Ancillary Inspection Services & Additional Topics 5 1/15/09 12:17 PM
Dryer Vent Repair Philadelphia nhagarty Ancillary Inspection Services & Additional Topics 0 1/12/09 9:22 PM
Dryer Vent Repair Montgomery County nhagarty Ancillary Inspection Services & Additional Topics 0 1/12/09 9:22 PM
Dryer Vent Repair Chester County nhagarty Ancillary Inspection Services & Additional Topics 0 1/12/09 9:21 PM
What is a 'condenser' dryer ?? rcooke Canadian Inspectors 9 9/9/07 7:02 PM
