On a recent inspection I noted high (35ppm +)levels of CO at the heat outlets (gas forced air furnace - I'm in Canada). I was actually in the house on two different days and took readings at two different times on both days with similar results. Each reading was taken over a 15 minute time span. The seller is in denial and had the gas co come out to check. They gave a report saying no problems.
1. is anyone else using the tpi775 meter? have you ever suspected false readings? 2. is there any condition in which a furnace can give off differing levels of CO? Can the length of time the furnace has been running influence this? |
| Find an InterNACHI certified Arkansas Home Inspector (and anywhere else in North America) |
gkay is a non-member guest and is in no way affiliated with InterNACHI or its members.
When was the last time you had your meter calibrated?
I've had this meter for about a year and a half.
There are variables such as down drafting.
Filter should be changed every year with heavy use. |
Consider a training course such as this:
http://www.nationalcomfortinstitute....ontraining.cfm Measuring for CO in ambient air is not as simple as waving the wand of your meter around a supply duct. Many inspectors do not understand or realize this. Calibration of your equipment is important as well. Submit your AWARDS NOMINATIONS here Visit the InterNACHI Awards web portal here Blessed are the blissfully ignorant... for they shall be easily led...
Try calibrating , But keep testing. I had a furnace guy denied there was a problem the agent insisted it be checked . Seller agent said i was being to picky. They sent a fellow in he found 3 small cracks. Trust your tools but keep them updated. test it where you know the air is clear. so far sense i started checking i have found 5 furnaces with problems Kinda makes you wonder how many problems are hiding. |
Wayne the "Deal Killer"
Fogarty Inspection Services Group of Knoxville TN Sean Fogarty Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.homeinspectionknoxville.com |
| CPSC -----> Recall on electric meter panels | pbolliger | Electrical Inspections | 0 | 10/16/09 12:23 AM |
| Panel and Meter | jwilliams7 | Electrical Inspections | 10 | 6/21/06 6:49 PM |
