ralexander1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Does anyone know when IRC REQUIRED the backup condensate drain line being plumbed to the exterior? Inspected a 1999 home and called out that the drain lines should (a) be plumbed to the exterior and (b) should drain over conspicuous location (door or window). Seller said builder came out and said it wasn't required. Thanks!
| Need a home inspection in Ohio? Check out InterNACHI's listing of Ohio certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
The IRC was first published in 2000, but that was pretty much a development of the CABO One And Two Family Dwelling Code. CABO was established in 1972, and the code dates back at least to 1987 (earliest copy I know of). Those model codes need to be locally adopted for the provisions to be a requirement.
But for a home inspector it really doesn't matter what the local requirements were at the time the system was installed. An AC unit above a finished space should have an secondary/emergency overflow pan with either a pipe to a visible location or a float switch in the pan ... so that when (not if) the primary line gets clogged the owner is hopefully alerted to a problem before any significant damage is done. JMO & 2-Nickels ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
| Got a letter from ASHI's President today. | gromicko | General Inspection Discussion | 55 | 12/12/10 11:51 PM |
| Condensate drain line | scroenne | Inspecting HVAC Systems | 1 | 5/5/10 7:07 PM |
| AC condensate pipe into drain line | jfrederick | Inspecting HVAC Systems | 1 | 11/3/09 11:54 AM |
| Importance of the AHJ check | mcyr | General Inspection Discussion | 6 | 2/21/07 8:18 PM |
| TPRV line and condensate line marriage | ccarrington | Plumbing Inspections | 3 | 4/29/06 7:59 AM |
