Do any of you check the evaporator coil in the HVAC equipment?
Reason for my question, is that we got a call from an agent stating that their clients AC unit went out and the home warranty company will not cover it because the coil as rust on it. We have never take apart the HVAC to check for rust, we just check temp and that the unit comes on in the cool mode and heat mode. We do recommend that if the unit as not been serviced within the last year that it be serviced by a HVAC technician. "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
| Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
If it's readily accessible (hand operated panel clips, for example), yes. If it requires removing screws or bolts, no.
NC SOP: HI is to..."open readily openable access panels provided by the manufacturer or installer for routine homeowner maintenance" “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
More proof as to what most, if not all, home warranties are worth.
If it is not visible are readily accessible I do not inspect item. Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
| Condensation Drain line question | acassady | Inspecting HVAC Systems | 25 | 2/26/12 11:40 AM |
| Rust on 2 year old evaporator coil | jonofrey | Inspecting HVAC Systems | 6 | 11/15/08 5:46 PM |
| Evaporator Coil Question | jfunderburk | Inspecting HVAC Systems | 17 | 1/18/06 1:13 AM |
