I have had some issues with renovators, the question being, placement of the cold air return in a finished basement. What is acceptable, ceiling height or floor height, not common practice.
| Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Opposite of supply vent.
You want the cold air coming back to the furnace if you can do it, that is near the floor or if you can't follow what Christopher said.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
The title of this thread was aimed at cold air return would someone define the word cold air why not the word warm air return In the world I worked in it was always referred to as simply return air. Where in the world would a return come back to if not the furnace do yous have a separate blower circulating air this makes no sense to me explain please Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Cold air return or air return. The biggest mistake people make when it comes to the air return is putting it on the ceiling in the basement. I know it is a challenge to get the air return near the floor but this is wear the cold air resides. You want the coldest air going back to the furnace and not the heated air. If you take back the heated air you are left with the cold air still at floor level. This is why in a cold climate it is next to impossible to keep a floor warm unless it is heated or well insulated. To combat the loss of warm air many put a door to the basement at the top of the stairs. This is no good because the heat will escape up to the door. If the door is installed on the bottom of the stairs the heat is maintained in the basement area and it prevents the stack effect.
Now the opposite is needed for cooling conditions but that is a new topic for discussion. We use the same principle in installation of a HRV, have all the warm air possible at the highest point pass across the cold air coming into the unit and extract the warm air from the exhaust. Not doing these simple tricks will make either your furnace or HRV not perform to its maximum potential. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
I was just wondering why the word cold is always attached to the words return air in the home inspecting world to me its like having an elevator in a out house
Get with the program Charlie. Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
I wuz about 18 years of age when I quit using the term (Hot water heater) that wuz immediately following the smack up side of my head with a pipe wrench by and old plumber
Cold air falls down the stairs to the basement, that's where the return air inlet belongs, on the floor at the foot of the stairs. If you have natural draft furnace, do not have the return air inlet too close to the furnace as back drafting can result.
Rick Strand, CPI CAHPI Associate Strand Home Inspections Inc. Calgary, Alberta, Canada Serving Calgary, Okotoks, Airdrie, Chestermere and Cochrane Alberta
Agreed
| Cold air return duct placement | abishop | Inspecting HVAC Systems | 3 | 5/26/11 3:09 PM |
| Cold air return | mthiltgen | Inspecting HVAC Systems | 13 | 3/27/09 4:20 PM |
| cold air return | salstad | Inspecting HVAC Systems | 5 | 3/9/09 8:48 PM |
| Cold air return and electrical romex | dmacy | Electrical Inspections | 12 | 1/3/06 6:16 PM |
