1.Hot water from the boiler enters the water heater ("COIL INLET")and circulates through a coil, heating water in the tank before...
2. Hot water exits the tank (COIL OUTLET) and heads back to the boiler to be re-heated. 3. Upon demand from a plumbing fixture hot water leaves the tank through the "HOT WATER" pipe. What's the cold water pipe for? Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
The cold water pipe is to let water into the water heater tank.
I believe the coil inlet and coil outlet are for a coil inside the waterheater tank. The water, to be heated in the water heater, comes in the cold inlet and out the hot outlet and is heated by the water from the boiler running through the coil. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Thomas Duchesneau is a non-member guest and is in no way affiliated with InterNACHI or its members.
In a one story house, the water pressure in the boiler is regulated down to 10-14 lbs and is totally separate from the domestic HW which is at street or well press.
| Venting an oil-fired water heater | mh718 | Inspecting HVAC Systems | 3 | 11/16/06 9:36 AM |
| TPR & Combusiton Air | thejnicki | Plumbing Inspections | 16 | 9/18/06 8:55 PM |
| Hot water heater Hot and Cold hookup | phughes | Plumbing Inspections | 20 | 5/11/06 1:04 AM |
| small valve on cold water supply ahead of water heater? | Walt Hoffman | Plumbing Inspections | 6 | 1/23/06 7:44 AM |
