1.Can you combine an oil fired boiler and a natural gas water heater into the same flue?
I also would like code references if you have them. 2. Is oil a solid fuel? Rick Kie |
| Find an InterNACHI certified Idaho Home Inspector (and anywhere else in North America) |
Oil gas can vent to same chimney 03 irc 2427.5.6.2 ..................03 nfpa 211 9.8.3
no common connection with solid fuel chimney 03 irc 1801.12 ...........................03 nfpa 9.7.12 Oil might be a solid fuel when it is frozen Ricky, wood, coal, and Uranium are solid fuels. |
Thanks for the help I will look these up. I called it out wrong, its not something we see everyday
Rick Kie |
| Gas Again | vsantos | Miscellaneous Discussion for Inspectors | 2 | 4/15/08 9:30 PM |
| No "H" clips? | jbreazeale | Structural Inspections | 7 | 5/17/07 3:28 PM |
| Another reason to recommend CO testers | rnewman1 | Interior Inspections | 2 | 10/12/06 8:47 AM |
| Fuel Master W/H date | bsmith | Plumbing Inspections | 2 | 6/2/06 11:59 PM |
