| HVAC Topics include heating, venting, and air conditioning. |
LinkBack | Thread Tools | Display Modes |
pominspections is a non-member guest and is in no way affiliated with InterNACHI or its members.
Got into a place today that had the combustion air supply cut as an opening into the floor with a register cover and it was pulling air from the crawl. My first reaction was "That's wrong". It's the first time that I have seen it done that way. The PVC exhaust vent on the roof also has an inordinate amount of moisture coming out of it. There was enough to freeze coming out. Also, this home has a lot of black marks around registers, under furniture and doors. The wife is a smoker, although not particularly heavy, and burns a number of candles. The filter on the system was not a disposable, but rather the cleanable and reusable type, and it was not dirty. My question I guess is could the combustion air being pulled from the crawl be causing some of this, or maybe the filter is just not up to the job of cleaning the air in this home? The furnace is about a year old installation and otherwise appeared to be serviceable.
As a guide look at "Code Check - HVAC"
Beyond that, or if something rubs you the wrong way, call for further evaluation by an HVAC specialist ... CYA (cover your assets) ... Robert O'Connor, PE Eagle Engineering & Inspections Adjunct Professor NACHI Education Committee www.reporthost.com/eagleengineering I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
That was my thought. Unit was located in a utility closet in the center of the home. Return air was located at the wall just below the cathedral ceiling in the LR.
| Display Modes | |
| Combustion air | sspradling | HVAC | 4 | 4/14/07 10:15 AM |
| Question re combustion air connected to vent | jhawes | Canadian Inspectors | 9 | 12/4/06 10:24 PM |
| Another reason to recommend CO testers | rnewman1 | Interior | 2 | 10/12/06 8:47 AM |
| Combustion Air Availability? | cradan | HVAC | 4 | 2/19/06 10:16 AM |
