At todays inspection the insulation on the combustion chamber of an old Repco appeared to be fiberglass. The buyer seemed to think it was asbestos. I offered that I didn't think so but the only sure way to determine that, would be to send a sample to a lab. I have never seen asbestos that looked like fiberglass - has anyone?
http://www.SmithHomeInspection.com SmithHomeInspection@yahoo.com NY State Lic. # 16000008304 631-434-5200 |
Movzet is a non-member guest and is in no way affiliated with InterNACHI or its members.
Great information
Bill A photo or more info would have been good. Mario 'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com |
Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
If it looks like cardboard it is most likely asbestos. Some older furnaces used this on the interior cabinet walls of the heat exchanger compartment.
Most likely fiberglass, but good answer if you are not sure. Do you have a picture?
Steve McIntire, Inspector EEinspections.com |
Yeah- it looked like fiberglass - didn't have the "cardboard" or corrugated look of typical asbestos. The buyer was pretty adamant so I thought I'd check with my "esteemed colleagues"
I don't know how far back this material was available ( I looked at a year a so ago) but it looked like asbestos and it was not.
The material was a white blanket you can buy from a industrial supply that handles very high temps. I believe it was part "woven glass" like . You can use an open flame and it will not burn. It was installed in a commercial level FAU . The side of the FAU H/E had this near a side panel to act as a heat shield. I will try and find it on line and post . Last edited by pbolliger; 10/2/06 at 9:54 PM.. |
Fiberglass Cloth withstands temperatures to 1,000°F.
December 2, 2004 - Manufactured from texturized fiberglass yarn, heat-resistant PARGLASS cloth contains no compound, cement, or wire and will not burn or smolder. It retains 25% of tensile strength, even when service conditions reach 1,000°F, and will not swell, shrink, deteriorate, or change chemically. Available in weights from 8.5–40 oz/yd², product can be aluminized on one side for thermal reflection or have brass or stainless steel wire inserts for increased tensile strength. Company web site More news from this company Search the industrial web for: "CLOTH, FIBERGLASS, HEAT SHRINK RESISTANT" Search for suppliers of:Cloth: High Temperature Cloth: Fiberglass Advertisement ![]() Archive Press Release (Products mentioned in this Archive Press Release may or may not be available from the manufacturer.) Release date: November 25, 2004 Heat-Resistant Fiberglass Cloth Product Line Available from Pars Manufacturing A line of heat-resistant, fiberglass cloth products, designed for use in foundry, metalworking, heat treating and other high-temperature industrial applications, is available from Pars Manufacturing Company, Ambler, PA. PARGLASS Fiberglass Cloth is a plain, tightly woven cloth manufactured from texturized fiberglass yarn; it contains no compound, cement or wire. Engineered to withstand temperatures up to 1000 degrees F, PARGLASS fiberglass cloth meets United States Coast Guard requirements for incombustible materials and will not burn or smolder. Recommended uses include welding curtains, fire blankets, insulation blankets, industrial and marine lagging, asbestos cloth substitute and drape cloth, among others. In contrast to many high temperature fabrics, PARGLASS cloth is exceptionally strong, retaining 25% of its tensile strength even when service conditions reach temps of 1000 F. Other properties include good thermal conductivity, high dielectric strength and low constants. Unlike other gasketing or insulating materials, the product will not swell, shrink, deteriorate or change chemically even after long exposure to water. PARGLASS Cloth is available in a variety of weights (8.5 to 40 ounces per square yard), finishes (heat-treated, waterproofed, weave set, renwet and/or flameproof), coatings (neoprene, vinyl, Teflon., and constructions (aluminized on one side for thermal reflection; with brass or stainless steel wire inserts for increased tensile strength). Company Information: Name: Pars Mfg. Co. Address: 101 S. Main St. City: Ambler State: PA ZIP: 19002-4717 Country: USA Phone: 800-871-5302 FAX: 215-646-1368 http://www.parsmfg.com/ |
How can you all speculate as to what this stuff is? Even if it looks like asbestos we can't say it's asbestos. Unless we send it off to a lab and verify, we don't know!!
| IAC2 In new residential construction | mcyr | IAC2 Indoor Air Forum | 0 | 10/9/07 7:45 PM |
| Vaulted Ceiling Insulation | rcooke | Canadian Inspectors | 3 | 1/22/07 11:24 AM |
| New Old Insulation | rcooke | Canadian Inspectors | 1 | 12/13/06 6:25 PM |
| Crawlspace Insulation | gbrasseur | Structural Inspections | 12 | 12/3/06 4:18 PM |
| Another reason to recommend CO testers | rnewman1 | Interior Inspections | 2 | 10/12/06 8:47 AM |
