Old 3/28/11, 11:50 PM
Darin Redding's Avatar
Darin Redding Darin Redding is offline
Default Compressor Disconnect Distance
In your opinion, do you see any problem with the disconnect being 13 feet away, and not in direct eyesight of unit?
Darin Redding, CPI
Housecall Property Inspections
san diego home inspection
rental inspection | warranty inspection
Facebook Like
darin@sandiegohomeinspect.com
619-663-8740
home inspector in San Diego, Carlsbad, Poway, La Mesa, El Cajon, Chula Vista.
Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/29/11, 12:25 AM
Charley L. Bottger's Avatar
Default Re: Compressor Disconnect Distance
With the unit sitting the direction that it is service ports are close enough for me to see the disconnect I would not call that one out
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 3/29/11, 1:01 AM
Thanks Charley.
Darin Redding, CPI
Facebook Like
619-663-8740
Old 3/29/11, 7:27 AM
Wayne B. Wilson's Avatar
I would be more worried about the problems with the stucco. BTW was there coils against the wall?
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 3/29/11, 11:59 AM
Yes, lots of moisture issues here which had caused stucco damage. Especially around the front where the stucco was in contact with the ground and they were irrigating the home more than their lawn.
What is your concern with the coils?
Darin Redding, CPI
Facebook Like
619-663-8740
Old 3/29/11, 12:29 PM
Air flow if that has a side coil to close to the home
Wayne Wilson
865-256-1490
Old 3/29/11, 2:54 PM
David P. OKeefe's Avatar
David P. OKeefe David P. OKeefe is offline
That's better than having it too close.
David
InterNACHI #08051301
NYS Lic. #16000038229
NYS DEC Cert # T4865884
518-505-8305
HouseAbout Home Inspections
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Old 3/30/11, 10:55 AM
Jeffrey R. Pope's Avatar
Most Rheem's only require 6" of clear space according to the manufacturers specs.
That disconnect is marginal IMO. As Charley stated, the orientation of the unit makes it somewhat acceptable, but the disconnect should have been relocated when the condenser was relocated.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Well distance from septic phalstead Florida Inspectors 5 1/18/11 10:02 PM
Distance between Refrigerator & Stove wrosario Interior Inspections 32 8/6/06 7:17 PM
Commercial Inspector Distance Training tchristopher Inspection Education & Training 1 1/4/06 8:48 PM
Proper distance between a washer drain pipe and 220 volt dryer connection rpaul Electrical Inspections 14 1/3/06 9:43 PM
