Old 11/3/08, 5:57 PM
Chuck Lad Chuck Lad is offline
Please Note: Chuck Lad is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Condensate Drain
I have received differing opinions regarding the proper method to maintain the condensate drain on a A/C unit. Some say it is OK to "flush" the drain periodically with a bleach solution -- and others indicate that bleach could damage the drain piping and the proper method is to flush with vinegar.
Looking for "expert"/experienced guidance.
Thank you.
Chuck
Old 11/3/08, 5:59 PM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is online now
Default Re: Condensate Drain
Diluted bleach should not hurt. Remember, bleach comes in plastic bottles
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 11/3/08, 6:19 PM
Emmanuel J. Scanlan Emmanuel J. Scanlan is offline
Diluted bleach should not hurt as stated above. However, plain white vinegar can be used with very good results. It is also much safer to handle and can be used undiluted. When asked by clients what to use for jetted tubs I tell them what we do. We use a gallon of white vinegar at least once a month and run it through the jets for 15 minutes. It cleans very well and will not damage piping, joints, nothing. White vinegar is also less liability for a proposed solution to a client.
Knowledge is power, but sharing knowledge brings peace!
http://www.psinspection.com
TREC License# 7593
Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC!
Old 11/3/08, 6:20 PM
Brian E. Kelly's Avatar
Thank you.
Chuck
If it is metal drain piping I would not use bleach myself. If it is pvc piping bleach or vinegar is fine.
I am leery myself on telling people to use bleach on anything as some people are not to be trusted with any chemicals what so ever.
Condensate shut off and pan drain? jweise Inspecting HVAC Systems 8 9/12/08 10:53 AM
Condensate pump instead of drain piping lfoster Inspecting HVAC Systems 7 6/22/08 4:16 PM
near correct condensate drain bking Inspecting HVAC Systems 2 9/19/07 2:51 PM
Condensate drain blowing cold air lfoster Inspecting HVAC Systems 50 9/9/07 7:05 PM
condensate drain lprinzi Inspecting HVAC Systems 3 8/11/06 6:57 PM
