Old 8/29/10, 11:21 PM
Scott Schultz Scott Schultz is offline
Please Note: Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default condensate dripping in air handler
I noticed my secondary condensate line was dripping in my house today so I climbed into the attic and noticed some water in the drip pan. I took the panel off to find water dripping from the fins on the coil. I am in AZ so humidity is low (around 10%) today. Coils didn't appear dirty and I have not noticed this happening before....the a/c has been running all summer. I got about a 11-12 degree split so maybe I need a little more freon but I wouldn't think it was low enough to cause the leaking.
Thanks
Need a home inspection in Oklahoma? Check out InterNACHI's listing of Oklahoma certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/30/10, 7:52 AM
Wayne B. Wilson's Avatar
Default Re: condensate dripping in air handler
If it is low on refrigerant ,there may be some ice forming around the coil. Can you view it?
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 8/30/10, 9:41 AM
Tom Leahy Tom Leahy is offline
main drain clogged?
Fort Worth Home Inspector
Dallas Home Inspector
Old 8/30/10, 1:53 PM
LOL - you guys in the low humidity zones may not see what we in the deep south see all the time. Here condensate will drip off the coil any time the A/C is running. However, back to the original question, if there is water in the secondary pan, the main drain line is plugged. Pour a little clorex into the clean-out opening (it does have one - right?) then clean out with a bottle brush.
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 8/30/10, 10:49 PM
The main line had condensate dripping from it and so did the secondary line.
Old 8/31/10, 5:18 PM
wsiegel wsiegel is offline
Sounds like you need to call an AC company
Old 8/31/10, 7:08 PM
Well, that adds a couple of possibilities. Either the internal pan has a leak or the main line is partially plugged causing the internal pan to run over. Either way, there should never be any water in the auxiliary pan.
Frank P. Newman
Dublin, GA
Old 9/4/10, 12:45 PM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
Condensate may be dripping from the main drain, however the drain may be restricted. If you have access to the main drain connect the hose of a wet/dry vacuum to the drain and tape it in place so that the vacuum doesn't leak. Turn the vacuum on. This will normally clear most plugs.
Condensation Drain line question acassady Inspecting HVAC Systems 25 2/26/12 11:40 AM
AC condensate drain into plumbing vent jfunderburk Inspecting HVAC Systems 4 5/7/10 1:42 AM
1 condensate line...... Scott Schultz Inspecting HVAC Systems 2 11/4/07 6:18 AM
air handler condensate pan bpinel Inspecting HVAC Systems 2 4/16/07 10:16 AM
