Old 6/30/10, 10:31 PM
Michael J. Merino's Avatar
Michael J. Merino Michael J. Merino is offline
Default Condensate line
Is it alright for the condensate line to empty to the outdoors? The inspection is in the Chicago area. Furnace is in the garage and exits the wall and empties in the yard. It just doesn't seem right to me.
Michael Merino
Merino's Home Inspection & Education Inc.
"Not just an Inspection, an Education"SM
Phone/Fax 708~535~6057
Need a home inspection in New Mexico? Check out InterNACHI's listing of New Mexico certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/30/10, 11:08 PM
Bob Elliott's Avatar
Default Re: Condensate line
It is fine Mike.
There is no condensate in winter.
Not as sure about open treads.
Now if that is also condensate from a Cat 4 I might worry about ice at those stairs.
Old 7/1/10, 1:02 AM
Tim Spargo's Avatar
As a side note... if the secondary is capped, as is common on a setup like this one, I'll recommend an alternate device to prevent damage to furnace/handler in case of a clog in the primary drain, which can be common in one like that
Tim Spargo
Spec Rite Inspections
661-317-5770
Old 7/1/10, 11:47 AM
On some newer 90% HVAC units that have PVC vent pipes that run to the sides of the exterior, some of these vent pipes may cause condensation at some time in the winter. Check the inside burner areas of these pipes. Condensate drains may be installed at the bottom of these pipes, that also run to the floor drain, or outside of the home. Very rare, however.
CMI, CPI, KS #0110-0094 Termite #16601
KS Radon #KS-MS-0027
BBB A+ Accredited Business
Serving the Greater Kansas City Metro Area
Eastern Kansas/Western Missouri
http://www.metrospeckc.com
"If opportunity doesn't knock, build a door"--Milton Berle
Condensate drain line scroenne Inspecting HVAC Systems 1 5/5/10 7:07 PM
Frozen condensate line dmiller6 Inspecting HVAC Systems 7 1/18/09 11:25 AM
1 condensate line...... Scott Schultz Inspecting HVAC Systems 2 11/4/07 6:18 AM
TPRV line and condensate line marriage ccarrington Plumbing Inspections 3 4/29/06 7:59 AM
