This unit had a sensor at the top of the line in case there was a clog in the pipe. It appears to me that if there was a problem with the drain line while the a/c unit was running it would just back into the furnace since they share the same pipe. I've not seen this setup before. Any thoughts?
| Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
The only way to fix stupid in this case is to cut it out and start over
I work on installs for high efficiency furnaces like that all the time, and the manufacturers actually want the condensate drain extension pipe a certain distance above the pressure switch taps to help ensure one of the pressure switches trips before the drain overflows.
Can't hurt to also install a moisture sensor on that pipe in the event the drain is clogged and the pressure switches fail. I don't see a cleanout though. Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... Last edited by roconnor; 10/17/11 at 8:27 AM.. |
Based on what I am seeing, the condensate float (kill )switch is much higher than the lip or top edge of the typical drain pan. The drain line will back up then the pan will fill up and spill over and the float switch never will engage to shut off the power. Might be the angle we are looking at but it does not look like it was installed correctly for its intended purpose.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
I meant to say the condensate drain extension needs to be above the pressure switch taps, which are connected to the pressure switch with small gray flexible tubing. Thats what many manufacturers want.
Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
| Condensation Drain line question | acassady | Inspecting HVAC Systems | 25 | 2/26/12 11:40 AM |
| Why is this happening in america "home of the free"? | gluck | Miscellaneous Discussion for Inspectors | 14 | 3/18/10 11:21 AM |
| Condensate piping | dmacy | Inspecting HVAC Systems | 15 | 3/13/07 12:17 AM |
| Vent Stack with Condensate Lines | hspinnler | Plumbing Inspections | 18 | 10/3/06 6:27 PM |
| TPRV line and condensate line marriage | ccarrington | Plumbing Inspections | 3 | 4/29/06 7:59 AM |
