Go Back   InterNACHI Message Board > Specific Inspection Topics > HVAC
HVAC Topics include heating, venting, and air conditioning.
Old 6/21/08, 11:13 AM
Linda J. Foster's Avatar
Linda J. Foster Linda J. Foster is offline
Question Condensate pump instead of drain piping
Saw a new one (for me, anyway ). The unit is an older Fedders, electric portion of split system. It's located in an interior mechanical closet.
Below the unit the condensate drain pipe entered this Little Giant Pump, Model VCMA-2OULS. The older drain line thru the slab was not being used.
I didn't try to move this unit, but it appears that the condensate entered this pump, and traveled no further. Does this pump dry the condensate?
No apparent stains to show that it hadn't been working.
ID:	22104   condensate-pump-instead-drain-piping-101_0112-medium-.jpg.jpg
Linda Foster
www.HomeInspectionsByFoster.com
HomeInspectionsByFoster@yahoo.com
(210) 347-1023
TREC #7654
InterNACHI #06032691
Old 6/21/08, 11:24 AM
Ralph Brady's Avatar
Ralph Brady Ralph Brady is offline
Default Re: Condensate pump instead of drain piping
It looks like a drain line out next to the condensate drain line in. I have seen these drain up through the roof next to the flue, a plumbing vent or a roof vent (among other places). There is a device or option which will turn the furnace off if the tank does not empty. I sometimes recommend they have one of those.
"An expert is a person who has made all the mistakes that can be made in a very narrow field"
Niels Bohr
"Learn all you can from the mistakes of others. You won't have time to make them all yourself"
Alfred Sheinwold
Eureka, Fortuna & Arcata, CA
Old 6/21/08, 12:37 PM
cbottger's Avatar
cbottger cbottger is offline
The plastic tygon hose is the discharge from the pump which is float activated and will discharge to god knows where I would have followed the hose to see where it went. Not an uncommon install at all if no drain opening are available
CMOR Thermography Certified Level 11 #2097
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
Professional Home Inspector State License # 130
Reporting system by Home Inspector Pro
Serving the State of Okla.
Old 6/21/08, 12:52 PM
cbottger's Avatar
BTW did that foam strip at the top of the return air box completely seal the return air off from the burner area of the furnace. That kind of a return usually get my attention as it is a poor set up that kind of foam usually does not last long and creates problems
NACHI Member
Old 6/21/08, 1:51 PM
Jeffrey R. Pope's Avatar
That's a relatively common installation in homes that were not originally built with A/C (cooling) systems. I often see these tapped into a plumbing vent or routed to laundry sinks and stand pipes.
You should recommend periodic monitoring to ensure the pump remains operational, and that there are no leaks in the discharge system.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 6/21/08, 3:24 PM
Frank J. Carey Frank J. Carey is offline
Ditto Jeff.
Very common in finished basements when the plumbing drains are not close to the units. They usually are pumped outside or to another fixture drain. Not worthe the cost of plumbing a seperate drain line to the units for the amount of condensate.
Frank
Carey Inspection Solutions, LLC
Wilkes-Barre/ Scranton PA
Nachi ID -> 08022204
Frank@careyinspectpa.com
www.careyinspectpa.com
www.frankcareyconstruction.com
Old 6/21/08, 4:21 PM
Thanks to all. I didn't initially look as close as I should have.
You folks are great !
Linda Foster
(210) 347-1023
TREC #7654
Old 6/22/08, 4:16 PM
William R. DeVries, CMHI's Avatar
William R. DeVries, CMHI William R. DeVries, CMHI is offline
What you also need to watch for with this type of soft hosing is when they zip-strap it that it does not colapse or twist the hose along the way
Certified Level I Thermography (ITC)
Certified Mold Inspector (Pro-Lab)
Certified Mold Inspector IAC2
Certified Home Inspector INACHI 07040201
Commercial Property Inspection
2008 InterNACHI member of the year
Magnum Property Inspection
Inspect it before you buy it
647 217 8473
We use and recommend
Home Inspector Pro Software
HomeGauge Software
980 Questions/Answers to the NHIE....Free! jbushart Legislation, Licensing & Legal Issues 50 4/20/08 2:26 AM
Do you put polybutylene in the Summary? jfunderburk Plumbing 36 11/27/07 12:56 AM
Condensate drain blowing cold air lfoster HVAC 50 9/9/07 7:05 PM
Condensate piping dmacy HVAC 15 3/13/07 1:17 AM
condensate drain lprinzi HVAC 3 8/11/06 6:57 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
